I've been around AVS for a long time, and this is one area I'd like to learn more about... creating a "Video Jukebox" of sorts using a Gen1 AppleTV that would allow the user to call up a menu on his/her Home Theater that would then allow you to select & view a video from a remote HDD attached to your computer. In my case it would be an iMac.
As a start, I picked up a used ATV (40GB) a few months ago that had specifically been modded and had a fresh install of Boxee and XMBC on it. My intent is to hardwire the ATV via ethernet to my 3COM switch (or my Airport Router) and have a dedicated USB drive connected to either the Airport or the iMac. I have a bit of work ahead of me in that I think my ATV does not have the latest and greatest "OS" and I have to find out if I can (or need to) upgrade the ATV before I start trying to figure this all out. I've read someplace about something called a "patchstick" which entails getting a decent quality USB flashdrive of at least 256KB and loading a utility onto it that will flash the ATV into a very current state of usefulness; meaning you should be able to use either the internal HDD and/or an External HDD to stream decent quality (720p?) video and audio to your big screen TV. Have to search my desk and find an decent USB stick or wait out the blizzard and pick one up at Costco or Staples.
Anyway... this is going to be a slow process for me as I'm going to try and find out as much as I can and if things work, I will obviously post back here in the spirit of sharing information. Likewise, if someone has already made this leap and would like to help me (and others) learn how to "build" a Video Jukebox using a Gen1 ATV... please jump in and give us some pointers and advice. All I ask is that the advice be at the novice level rather than the full-blown technogenius level LOL!
