I have a notebook capable of nVidia's 3DVision with HDMI 1.4 and VGA outputs (No DVI). The external 3DVision monitor I want to get only does 3D with a Dual-Link DVI-D input.
From what I've read, the only HDMI cable that is electrically compatible with Dual-Link DVI is the Type B, which as far as I know hasn't actually been produced yet. Also, I understand that the specs for HDMI 1.4 limit the refresh rate to 24Hz for 1080p, which is rather low, although I don't know if the video card (460M) is capable of forcing 120Hz somehow.
So, do you have any thoughts on how to connect this monitor?
As I mentioned, the only other output my notebook has is VGA. If I still want an LCD monitor and no HDMI->DVI converter exists for my particular case, would it be reasonable to look for a different one that can do 1680x1050 (306 MHz of the 400MHz of the VGA spec) at 120Hz?
