AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Onkyo RC-693M Remote
post #1 of 3
For some reason, my Onkyo 705 remote has all of a sudden begun responding very slow to adjust the volume. I changed the batteries and all but to no avail. I can adjust the volume at the unit with no problem and all other functions seem to work properly. Any one have any advice or suggestions.
Golfman8
post #2 of 3
I have the same problem
have you found a solution ?
post #3 of 3
You might check here for some troubleshooting tips > http://www.justanswer.com/electronics/4jgcb-onkyo-tx-sr705-the-remote-control-rc-693m-stop.html
  Back to Forum: Remote Control Area
