Originally Posted by wnielsenbb
Those are input modes. This thing only outputs 720p120. It will not do 100hz.
xbox cod runs side by side. It works, but the ir port doesn't work so I had to use dlp link glasses, so no good for crt. There may be some device that will support your crt. I know I used to game 3D on a crt with wicked3d drivers for my 3dfx card. That was like 12 years ago
Re the IR port not working that's not quite correct. If you're using an amp to route video to a port on the 3dxl You can trick the 3dxl into activating the IR port for SBS by feeding it a frame packed source like a 3d blu ray player or a ps3 (in my case I just throw socom or kill zone in the ps3) with the emitter plugged in. After that swap input on your amp over to the xbox 360 and hit the SBS button. I have done this myself and got the 3dtv Corp emitter to talk to my genuine nVidia glasses at the same time. It's a very convoluted work around though and really not good enough on Optoma's part.
