Originally Posted by rdjam
Was the French review talking about 1080i SBS conversion to 720p, or about 1080p24 frame packed (Bluray) conversion to 720p?
The review was talking about 1080p24 frame packed Bluray.
Yes - I would let the projector handle any scaling where possible. However, in the case you the single projector DLP-Link application you have no choice but to have the scaling done in the 3DXL I would guess, if coming down from 3D Bluray.
If running single 3D-XL with DLP-Link projector you would probably be best of setting your 3D-Bluray player, HTPC or PS3 to output 720p60 manually if possible so no downscaling is done by the 3D-XL. 720p all the way through to the 720p projector.
If running dual 3D-XL with dual projectors, one would like to have 1080p24 bluray coming thru untouched to the dual 1080p projectors (which is now output at 1080p60 and thats ok since there will be new firmware later).
However when running 720p60 (PS3 games) to this DUAL 3D-XL configuration, you say that 720p will be preserved although the 3D-XL manual says specifically that everything in a dual setup will be output at 1080p60.
rdjam, since your are currently testing your 3D-XL boxes, could you somehow please confirm that if fed a 720p hdmi1.4 framepacked 3D signal in dual config (L or R set on the back) the 3D-XL will also output 720p? I am confused since the manual of the 3D-XL says otherwise.
3D-XL manual (page 13):
http://www.optoma.no/uploads/manuals/3D-XL-M-en.pdf
French review translated to english: (go to "First impressions with a Blu-ray 3D")
http://translate.google.se/translate...ptoma-3d-xl%2F
