1) $652 TOTAL PACKAGE
http://www.newegg.com/Product/Produc...-010-_-Product
These sounded OK to me at a local Bestbuy. $600 plus another $52 for the Ipod dock and I'm done.
2) $599 TOTAL PACKAGE
http://www.newegg.com/Product/Produc...sch%20hd%20500
I heard these at a local PR Richard and they were a bit harsh, but very loud and actually sounded much better than I thought. The lower model HD 300 is garbage. Sounded terrible all around. This HD is a huge step up.
3) $751 TOTAL PACKAGE
http://www.amazon.com/Energy-Classic...pr_product_top
I would go for either of these Takes OR the RC-Micro's, which both can be had for $399 each. Add a nice Yamaha or Onkyo receiver from Newegg for about $300, worthy of doing the job and comparable to the other above receivers and an Ipod dock for about $52, that'll be total $751.
This is all going into my Living Room/Dining Room combo that is opened into each other and is 25' Long X 11' Wide X 8' High total. The actual Living Room and 5.1 system will be ONLY in the LR half of this entire space. Nevertheless, it will still be opened throughout. And another huge situation is that my sub HAS to be behind the wedge of my sectional in the MIDDLE of that 25' X 11" space! Can not put it up front due to space limitations. May have to upgrade my sub dow n the road. I can't spend anymore than this for now.
A simple system 1, 2 or 3 would suffice if you like!
ALL and any comments is much appreciated!
Thanks, Pete
Thanks, Pete
