AVS › AVS Forum › Audio › Soundbars › Soundbar setup question
post #1 of 2
Please help.
I have a Sony KDL-46EX500. I just bought a Polk Audio SurroundBar3000.
I can only get sound out of the sound bar on my "Component 1" input. I would like to use it on my HDMI 1 input.
The sound bar is connected to the TV via optical cable.
Any ideas on how to do this?
post #2 of 2
If you are passing the sound from the TV to the soundbar via optical, it should play whatever is on the TV no matter which input is being used.
You should make sure that your internal speakers are turned off and the TV set to "Home Theater" or some similar mode.
With some TV's like my Panasonic, you have to specify on HDMI inputs how the audio is handled.
  Back to Forum: Soundbars
