post #1 of 1
Hi,
I hooked up my MacMini to a Sharp LC-42RD1E via MiniDisplayPort to HDMI.
After some reading in this forum I achieved to have a resolution of 1216x680 (by starting at 1280x720 with overscan and reducing with SwitchResX to fit my screen). The result is however not satisfying at all.
Which other resolution should I try in the light of the EDID of the Sharp, which I display below. What is the difference between the timings in the Monitor Description blocks, the standard CEA Timings in the EXTENSION EDID BLOCK 1 and the detailed timing blocks?
The standard CEA Timings #1: 1920 x 1080i @ 50Hz - 16:9 - '1080i25' says to be native, but the Detailed Timing Block 1 also claims to be native (Detailed Timing Block #1 - Timing definition: Mode = 720 x 576 @ 50,000Hz), quite small BTW. And the monitor description blocks lists two different timings (1920 x 540 @ 50,044Hz Interlaced and 720 x 480 @ 59,940Hz Non-Interlaced).
On top of that the Manual of the Sharp says the panel has 1366x768 pixels.
Can someone explain to me how this all works together and more importantly, which resolution I should choose? However, I tried 1366 x768 with SwitchResX with no success.
Any help would be greatly appreciated, since I am quite lost.
Dimitri
Here the EDID from the Sharp:
Code:
DDC block report generated by SwitchResX version 4.2 for display
SHARP HDMI
------------------- RAW DATA ------------------------
      0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
0  | 00 FF FF FF FF FF FF 00 4D 10 EB 0F 01 01 01 01
1  | 00 10 01 03 80 00 00 78 2A 1B BE A2 55 34 B3 26
2  | 14 4A 52 00 00 00 01 01 01 01 01 01 01 01 01 01
3  | 01 01 01 01 01 01 01 1D 80 D0 72 1C 16 20 10 2C
4  | 25 80 00 00 00 00 00 9E 8C 0A D0 8A 20 E0 2D 10
5  | 10 3E 96 00 00 00 00 00 00 18 00 00 00 FC 00 53
6  | 48 41 52 50 20 48 44 4D 49 0A 20 20 00 00 00 FD
7  | 00 31 3D 0F 2E 08 00 0A 20 20 20 20 20 20 01 7D
0  | 02 03 21 71 4D 94 05 13 04 11 12 02 03 15 16 06
1  | 07 01 23 09 07 07 83 01 00 00 66 03 0C 63 20 00
2  | 80 8C 0A D0 90 20 40 31 20 0C 40 55 00 00 00 00
3  | 00 00 18 01 1D 80 18 71 1C 16 20 58 2C 25 00 00
4  | 00 00 00 00 9E 01 1D 00 BC 52 D0 1E 20 B8 28 55
5  | 40 00 00 00 00 00 1E 01 1D 00 72 51 D0 1E 20 6E
6  | 28 55 00 00 00 00 00 00 1E 00 00 00 00 00 00 00
7  | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53
 <  00FFFFFF FFFFFF00 4D10EB0F 01010101 00100103 80000078 2A1BBEA2 5534B326 144A5200 00000101 01010101 01010101 01010101 0101011D 80D0721C 1620102C 25800000 0000009E 8C0AD08A 20E02D10 103E9600 00000000 00180000 00FC0053 48415250 2048444D 490A2020 000000FD 00313D0F 2E08000A 20202020 2020017D      02032171 4D940513 04111202 03151606 07012309 07078301 00006603 0C632000 808C0AD0 90204031 200C4055 00000000 00001801 1D801871 1C162058 2C250000 00000000 9E011D00 BC52D01E 20B82855 40000000 00001E01 1D007251 D01E206E 28550000 00000000 1E000000 00000000 00000000 00000000 00000000 00000053        >
 {  0x00, 0xFF, 0xFF, 0xFF,  0xFF, 0xFF, 0xFF, 0x00,  0x4D, 0x10, 0xEB, 0x0F,  0x01, 0x01, 0x01, 0x01,  0x00, 0x10, 0x01, 0x03,  0x80, 0x00, 0x00, 0x78,  0x2A, 0x1B, 0xBE, 0xA2,  0x55, 0x34, 0xB3, 0x26,  0x14, 0x4A, 0x52, 0x00,  0x00, 0x00, 0x01, 0x01,  0x01, 0x01, 0x01, 0x01,  0x01, 0x01, 0x01, 0x01,  0x01, 0x01, 0x01, 0x01,  0x01, 0x01, 0x01, 0x1D,  0x80, 0xD0, 0x72, 0x1C,  0x16, 0x20, 0x10, 0x2C,  0x25, 0x80, 0x00, 0x00,  0x00, 0x00, 0x00, 0x9E,  0x8C, 0x0A, 0xD0, 0x8A,  0x20, 0xE0, 0x2D, 0x10,  0x10, 0x3E, 0x96, 0x00,  0x00, 0x00, 0x00, 0x00,  0x00, 0x18, 0x00, 0x00,  0x00, 0xFC, 0x00, 0x53,  0x48, 0x41, 0x52, 0x50,  0x20, 0x48, 0x44, 0x4D,  0x49, 0x0A, 0x20, 0x20,  0x00, 0x00, 0x00, 0xFD,  0x00, 0x31, 0x3D, 0x0F,  0x2E, 0x08, 0x00, 0x0A,  0x20, 0x20, 0x20, 0x20,  0x20, 0x20, 0x01, 0x7D,       0x02, 0x03, 0x21, 0x71,  0x4D, 0x94, 0x05, 0x13,  0x04, 0x11, 0x12, 0x02,  0x03, 0x15, 0x16, 0x06,  0x07, 0x01, 0x23, 0x09,  0x07, 0x07, 0x83, 0x01,  0x00, 0x00, 0x66, 0x03,  0x0C, 0x63, 0x20, 0x00,  0x80, 0x8C, 0x0A, 0xD0,  0x90, 0x20, 0x40, 0x31,  0x20, 0x0C, 0x40, 0x55,  0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x18, 0x01,  0x1D, 0x80, 0x18, 0x71,  0x1C, 0x16, 0x20, 0x58,  0x2C, 0x25, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00,  0x9E, 0x01, 0x1D, 0x00,  0xBC, 0x52, 0xD0, 0x1E,  0x20, 0xB8, 0x28, 0x55,  0x40, 0x00, 0x00, 0x00,  0x00, 0x00, 0x1E, 0x01,  0x1D, 0x00, 0x72, 0x51,  0xD0, 0x1E, 0x20, 0x6E,  0x28, 0x55, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00,  0x1E, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x00,  0x00, 0x00, 0x00, 0x53,         }
        Valid EDID block: checksum passed
------------------- MAIN EDID BLOCK -----------------
EDID Version........1.3
Manufacturer........SHP
Product Code........60175 (EB0F) (0FEB)
Serial Number.......01010101
Manufactured........Week 0 of year 2006
Gamma...............2,20
Display Supported Features:
        Power Management: Active off
Display type:
        RGB 4:4:4 & YCrCb 4:4:4 Color Encoding Formats
        Display is non continuous frequency
        Default color space is not sRGB standard
        Preferred timing mode includes Native Pixel Format
Input signal & sync:
Digital Input
        Color Bit Depth is undefined
        Digital Interface is not defined
Color info:
Red x = 0,633  Green x = 0,205  Blue x = 0,150  White x = 0,292
Red y = 0,333  Green y = 0,702  Blue y = 0,081  White y = 0,322
Established Timings:
Manufacturer Reserved Timings:
Standard Timing Identification:
Monitor Description blocks:
        Descriptor #0 - Timing definition:
        Mode = 1920 x 540 @ 50,044Hz
                Pixel Clock............. 74,25 MHz              Interlaced
                                        Horizontal              Vertical
                Active.................. 1920 pixels             540 lines
                Front Porch.............  528 pixels               2 lines
                Sync Width..............   44 pixels               5 lines
                Back Porch..............  148 pixels              15 lines
                Blanking................  720 pixels              22 lines
                Total................... 2640 pixels             562 lines
                Scan Rate...............  28,125 kHz             50,044 Hz
                Image Size..............    0 mm                   0 mm
                Border..................    0 pixels               0 lines
                        Sync: Digital separate with
                                * Positive vertical polarity
                                * Positive horizontal polarity
        Descriptor #1 - Timing definition:
        Mode = 720 x 480 @ 59,940Hz
                Pixel Clock............. 27,00 MHz              Non-Interlaced
                                        Horizontal              Vertical
                Active..................  720 pixels             480 lines
                Front Porch.............   16 pixels               9 lines
                Sync Width..............   62 pixels               6 lines
                Back Porch..............   60 pixels              30 lines
                Blanking................  138 pixels              45 lines
                Total...................  858 pixels             525 lines
                Scan Rate...............  31,469 kHz             59,940 Hz
                                * Negative vertical polarity
                                * Negative horizontal polarity
        Descriptor #2 - Monitor name:
                        SHARP HDMI
        Descriptor #3 - Monitor limits:
                Horizontal frequency range.......15-46 kHz
                Vertical frequency range.........49-61 Hz
                Maximum bandwidth unspecified
------------ EXTENSION EDID BLOCK   1 ---------------
CEA-EXT: CEA 861 Series Extension:
        Revision:..............................3
        First DTD block at offset..............29
        Display Supports:
                basic audio
                YCbCr 4:4:4
                YCbCr 4:2:2
Data Block Collection:......1
        Video Type: standard CEA Timings
        #1: 1920 x 1080i @ 50Hz - 16:9 - '1080i25' is native (20)
        #2: 1920 x 1080i @ 59.94/60Hz - 16:9 - '1080i' is not native (5)
        #3: 1280 x 720p @ 50Hz - 16:9 - '720p50' is not native (19)
        #4: 1280 x 720p @ 59.94/60Hz - 16:9 - '720p' is not native (4)
        #5: 720 x 576p @ 50Hz - 4:3 - '576p' is not native (17)
        #6: 720 x 576p @ 50Hz - 16:9 - '576pH' is not native (18)
        #7: 720 x 480p @ 59.94/60Hz - 4:3 - '480p' is not native (2)
        #8: 720 x 480p @ 59.94/60Hz - 16:9 - '480pH' is not native (3)
        #9: 720(1440) x 576i @ 50Hz - 4:3 - '576i' is not native (21)
        #10: 720(1440) x 576i @ 50Hz - 16:9 - '576iH' is not native (22)
        #11: 720(1440) x 480i @ 59.94/60Hz - 4:3 - '480i' is not native (6)
        #12: 720(1440) x 480i @ 59.94/60Hz - 16:9 - '480iH' is not native (7)
        #13: 640 x 480p @ 59.94/60Hz - 4:3 - 'DMT0659' is not native (1)
Data Block Collection:......2
        Audio Type - not interpreted
Data Block Collection:......3
        Speaker allocation - not interpreted
Data Block Collection:......4
        Found HDMI 1.3a IEEE Registration Identifier - Deactivated by SwitchResX4
Detailed Timing Blocks - 1 is native
                                        Horizontal              Vertical
                Active..................  720 pixels             576 lines
                Front Porch.............   12 pixels               5 lines
                Sync Width..............   64 pixels               5 lines
                Back Porch..............   68 pixels              39 lines
                Blanking................  144 pixels              49 lines
                Total...................  864 pixels             625 lines
                Scan Rate...............  31,250 kHz             50,000 Hz
        Detailed Timing Block #2 - Timing definition:
        Mode = 1920 x 540 @ 60,053Hz
                                        Horizontal              Vertical
                Front Porch.............   88 pixels               2 lines
                Blanking................  280 pixels              22 lines
                Total................... 2200 pixels             562 lines
                Scan Rate...............  33,750 kHz             60,053 Hz
        Detailed Timing Block #3 - Timing definition:
        Mode = 1280 x 720 @ 50,000Hz
                Pixel Clock............. 74,25 MHz              Non-Interlaced
                                        Horizontal              Vertical
                Active.................. 1280 pixels             720 lines
                Front Porch.............  440 pixels               5 lines
                Sync Width..............   40 pixels               5 lines
                Back Porch..............  220 pixels              20 lines
                Blanking................  700 pixels              30 lines
                Total................... 1980 pixels             750 lines
                Scan Rate...............  37,500 kHz             50,000 Hz
        Detailed Timing Block #4 - Timing definition:
        Mode = 1280 x 720 @ 60,000Hz
                                        Horizontal              Vertical
                Front Porch.............  110 pixels               5 lines
                Blanking................  370 pixels              30 lines
                Total................... 1650 pixels             750 lines
                Scan Rate...............  45,000 kHz             60,000 Hz
