Originally Posted by
carp
So you are saying that if I am watching a source that is 5.1 (most blu-ray's, some cable content) I should NOT use PLIIx?
Where did I say that? I simply explained that PLII can only be applied to 2-channel sources, not 5.1 sources. This was in reply to you saying that you had only tried PLII with 2-channel sources on your 5.1 set-up. My point was that you didn't have a choice: with 5 speakers you can only use PLII (PLII
x will be grayed out by your receiver), and only apply it 2-channel sources.
If you have a 5.1 source AND more than 5 speakers (6 or 7), you can use PLII
x to scale the number of channels in the source to the number of speakers in your set-up. For the record, I would recommend leaving PLII
x on for all sources, 2-channel and 5.1-channel.
carp
PLIIx - I am still confused if I should use this or not. I know it uses the 2 rear surround channels but are the rest of the channels discrete?
When PLII
x is applied to a 5.1 source, only the front channels remain discrete. 3 channels, 3 speakers, nothing to process. Each channel is routed to its respective speaker.
The processing happens in the surround field, where the contents of the 2 surround channels are steered over your 4 surround speakers. Sounds that are mixed to both the left AND right surround channels, and would normally phantom image behind you, are extracted and sent to the speakers behind you. Sounds that mixed mostly in either the left OR right surround channel are kept at your left or right side. This is how you get rear-vs-side separation in the surround field. Since each surround channel is separated into two parts, side and rear, they are no longer discrete (i.e., no longer exactly what was on the disc).
