Originally Posted by
workinghard
I dont think anybody has questioned that have they? It also cost over twice as much as the M400 though.
Yeah, Marcolisi asked the question if we thought the M41 would have the same performance of the G10, so I was responding to that question. But yes, there is a big price difference.
One of the bigger differences in my mind between the M series and G is the lens. You get a much wider FOV with the G series. So if that's important to you, then it might be worthwhile.
