I always prefer a discrete surround back channel for DTS-HD, not least because my amp could actually recognise it and I wouldn't have to manually activate the EX processing.
Originally Posted by BsRoz
The issue here isn't so much if it would be possible for the extended films to be on only one disc, but rather if an a/v presentation without too much compromise would still be manageable in such a situation. A 4-hour AVC-encode with bitrates hovering in the low 20's could be a realistic scenario, but not very likely given Warner's track record of putting large numbers of international dubs on their discs.
If the theatrical BDs were any indication, then Warners won't be making this as a 'one for all' disc because the rights are scattered about due to the pre-existing New Line distribution structure. UK version had English language only, German version only had German & English etc etc.
In any case, is it really that objectionable to have the film on two disc? I can't imagine it being any kind of hassle to take 30 seconds to swap the disc in your player after two hours of watching.
A more seamless transition would be nice, rather than that crappy 'insert disc 2 to continue the journey' message which flashed up on the DVD, but apart from that I don't mind changing over at all.
![The Lord of the Rings: The Motion Picture Trilogy (The Fellowship of the Ring / The Two Towers / The Return of the King Extended Editions) [Blu-ray]](http://cdn.avsforum.com/2/2d/50x50px-ZC-2d3669c4_B0026L7H20-516cftBcvzL.jpeg)
) to 15-20 with no effect on compression transparency. I've tried with x264, and I've failed.
), these are the average bit-rates a single disc could provide each movie, one language track, no commentaries (video/audio):
