Originally Posted by Bohanna
Until someone comes up with definitive lumen standard that can be interdependently verified the folks in product marketing will continue to mislead and confuse the public. IN most cases there is no mention and measurement of the color temps used or the size of the image used when testing. Most projector manufacturers post their Lumen numbers implying the more lumens the better. Getting a lumen meter is kind of a waist of time unless you are going to be A/B comparing the exact same size images. My general rule of thumb is 120 watt UHP lamp 750 - 1000 lumens ,, 150 watt uhp 1200-1800 lumens 200 watt UHP 1900-2500 and so on. I know its not really scientific but it gives the user a pretty good idea of how bright a projector is going to be.. The Cre seems to be bright enough to put up a good size and quality image in a semi dark room. Since most of the people who are interested in the product are attracted by the lifetime LED it seems like a pretty good bargain. My only concern would be the organic panels vrs the inorganic panels.
Bohanna
Bohanna
You are correct about ANSI lumens, however, Runco has tried to solve this. It really only works for their projectors because no one lese uses it, but very useful when comparing theirs.
CSMS Cinema Standards Measurement System
http://www.runco.com/magic/csms-information/
Their numbers hold true as I have owned various models from Runco and Vidikron and the CSMS numbers show their numbers work.
Also it depends on how much a company inflates their numbers. I have a 700 ANSI lumen projector that calibrates to 435 Lumens at D65. My last one was 1280 lumens and calibrated to 485 lumens at D65. I have also had a stated 1250 ANSI lumen projector that calibrated to 400.
Eat Meat
Chi-Lin based LED projectors are water cooled (SIM2, Vango, wolf, etc) DP, PD, Runco, and others use the Delta chassis and that is cooled with 6 80mm fans. 3 intake and 3 exhaust!
