I now own one of these new, ordered back in October 2012, arrived promptly. Wanted to share my experience so far.
I'm new to the forum, thanks so much everybody on this tread for all their previous contributions, that really helped me decide to bite the bullet.
I'm a creative/engineer/entrepreneur type who wanted a new display system for my work/play. About 70% work coding, 5% video games, and 25% movie watching material as typical use. Coming from a variant of Mac and PC, DVD and eventual Blueray sources.
Of the two models/lenses. I chose the 'long throw' so that I could have a smaller screen/brighter as I wanted to use it during the day. . I ordered 1 projector, with the potential use of 3-4 of them in a seamless display to replace my desktop 4 multimonitor setup.
It's a 73" diagonal at 9'ft distance, max the room will allow.
SUMMARY: The projector is goodish value but not without it's significant drawbacks.
PROS
CONS
Ordered it directly from Hans, paid via Western Union payment which was less than the paypal overhead and a slower fedex option that still arrived in about a 7 -10 days from China to California, combined these saved about $50 provided you have cash instead of credit.
I'm using it with laptop sources:, XP, Windows7 and Mac mini. VGA and HDMI.
Calibration is actually tricky with the stack of stuff between sources and the projector: 1) PowerDVD having color calibration, 2) Nvidia having significant color controls (separate in desktop and video playback), and the 3) projectors onboard stuff in the (a) normal menu and (b) 'service menu'.
I have a variety of other sources, from DLP projector to LED backlight flat panel, ipad etc, this projector feels like a older generation LCD panel glued to the wall. The colors/and details seem better on more recent displays (e.g. IPS displays), but I hope it can be improved with additional calibration.
I don't think I'll order more or get into reselling it based on it's current state, but I do think this projector is a good sign as to where things are going, and certainly relative to other projects I've seen/have a viable entry.
Edited by TroyWorks - 11/26/12 at 12:59am
PROS
- very quiet, way quieter than my normal room fans.
- small + light weight,
- relatively fast on/off, about 30-1minute trips, no worries about about the bulb.
- runs cool, especially relative to my conventional projector exhause.
- bright, daylight viewable if not direct sunlight.
- good color intensity/range.
- 100% optical image shift up/down, very helpful in many projector setups vs keystone in software.
CONS
- mediocre color convergence, red is like 2pixels to the left and green 1 pixel from the right. On most DVD material when scaled up it's mostly unnoticable, on data (e.g. windows) you get undesirable edges, or mini rainbow on white stars on dark. This comes from the 3 color system ..most projectors have just one lcd which means that you end up with 3 colors side by side. In theory this should produce a superior display, one on screen pixel for one expected pixel. Instead I have talked with Han about it getting it fixed and was told "this is as good as it's going to get, any change will make it worse". Which I don't entirely buy as having 3 color projectors in the past which have either mechanical or software based (tedious) color calibration.
- the left edge is significantly distractingly darker (10%?) than the rest for about 3" in. It might be actually just bluer that is particularly annoying on flat field shots
- the right edge is a tad yellower similar to the left edge
- the bottom and top have a much lesser darker but is mostly unnoticeable.
- focus across the screen is not consistent, making it hard to impossible for tiny data.
- color is almost oversaturated, with the tools i have I find it tricky to balance it, from being overblown. Still working on it.
- black (projected on a conventional wall or flat matte white projection sheet) is blue/green, and things tend to get lost in it, which is often accentuated on 'low res" eg. dvd. I'm never sure sometimes if I'm seeing what's intended or miscalibrated.
- gamma is tricky to impossible to calibrate so far, no controls exist in the projector either.
- the zoom/focus are combined and a bit tricky, the focus uses these indents which is somewhat helpful but enough friction to try and get one, it often overshoots.
- the dust cap is poorly designed being very snug it's impossible to put on and off for me without also affecting focus.
- plasticy shell, makes it feel more flimsy than the interior is built at least from photos.
- have to output 60hz for the projector to pick it up
- no saturation controls enabled (why?) in menu.
- mediocre IR remote control, rubbery buttons are hard to tell if pressing does anything or not, and often don't work unless pointed directly at the projector.
- the onboard settings seem to be forgotten when the display is disconnected
- when a display is disconnected it goes to a blue splash screen with green i guess half brightness, makes everything white look yellow.
so I guess I'll put it on Ebay.
