Not sure how relevant this thread is anymore, emailed Han this week, the X1000 is no longer being made, plus no more updates to it. Then X2000 is the only thing being made now, which supposedly is an inferior built projector (thus cheaper), but no updates have been made to the X2000 since my last talking about it's issues.
On my X1000 ran into a couple new issues, the other day switching from PC output 1920x1200 to projector the projector couldn't figure out what to do, so had really wierd almost non-visible output. Turns out it lost it's mind and the various settings that showed up in the user adjustments weren't actually the one being used, and I had to switch to some other preset and back to correct itself.
After that the red has for a bit a streaky quality that showed up on some scenes, though it's always been possible to see a ghosting at times in dark scenes, as it feels like the active matrix in the LCD is passive matrix so for example if there are strongly activated section at the bottom the ones at the top are weaker/brigher than then should be
I'm still mixed on the price/value ratio. It really bugs me how often I have to fiddle with the projector to get it to display right when my machine changes resolution, or shuts down. So far the best I've been able to figure out is just to leave the laptop it's connected to on all the time.
The display *IS* HD from pixel tests but the quality of the HD is so poor, makes things like reading the web or any sort of data (excel) like running it through a fuzz filter. The lack of precise color calibration and overall medicore color contrast are a 1-2 punch to make things almost unreadible, even if properly focused. The best solution is just cranking up the text size or lowering the resolution on the projector which takes half the fun outof having a HD projector and it's not massively better than having my old SVGA projector aside from noise level.
But overall the direction these projectors are going is still encouraging, and in movie watching mode and game mode, my Girlfriend and I have gotten a lot of enjoyment from this... I can't wait to see what we get a couple years from now.
that is ordinary chinise circus. They are absolutely don`t know what are you talking about.
), it took a lot of non-linear settings, the one im still figuring out is nonlinear brightness it boosts up sometimes way too high so gotta get it lower too
