Originally Posted by action_jackson
What I'm saying is that the LED lights that are used don't put out any ultraviolet light to be filtered or to burn the LCD panel. I have been researching these lights and found a video of some engineers talking about these PT120 LEDs which confirmed my evaluation of the spec sheet.
I understand what you are saying. However I find it hard to beleive. I know that the reason for the blue screen burns on LCD projectors is the amount of light bombarding the Blue screen and polarizer. The conventional opinion is the culprit is the UV light but there may be more to it. I would like to see a screen shot with the yellow spots that sellmejunk is talking about and find out if they are getting bigger. Since these units have just come out the people who are buying them are in essence beta testers. They may have to put some sort of filter in front the blue screen to tamp it down a bit and crank up the airflow in the light block to keep any stagnent light from building up heat. This is only speculation on my part but it makes sence. So far this unit has been pretty impressive all things considered but this could be it's fatal Flaw. They seem to have the brightness issue under control and at this price it may be worth the dimness trade off. However if the yellow screen issue is this apparent this close to the purchase date there is Gonna be a HUGE problem
Bohanna
Bohanna
Bohanna
Bohanna
Bohanna
