This thread is intended to provide discussion of the calibration of JVC DLA-RS40 and X3 projectors. While these projectors lack a full Color Management System (CMS) capability, they can benefit from proper calibration for correct grey scale, gamma and color accuracy (within the constraints of not having a full CMS).
The DLA-RS40 and the DLA-X3 are essentially identical projectors except for a minor cosmetic difference. All references to the RS40 below equally apply to the X3.
This first post of the thread will be updated and expanded over time.
The RS40 (also includes RS50 & RS60) Owner's Manual (multi-language version) is available for download HERE (US version)
Firmware updates for the RS40/X3 are available for download HERE (US JVC)
Main RS40/X3 Owner's Thread is HERE
The AVS Thread for the calibration of the previous generation RS20/HD750 projectors is HERE
Most of the adjustments necessary to calibrate the RS40 can be accessed via the user menus. However, there are some additional adjustments and information that is only available via the projector's service menu. To access the service menu:
CALIBRATION TOOLS
The essential tools you will need for calibration of your JVC projector are a PC (a laptop is the most convenient), a optical sensor (colorimeter), a Blu-ray compatible disc with a set of HD test patterns, and colorimeter software for your PC that will record and report the measurements. Assuming you already have the PC and a blu-ray player, the only things above that you will actually need to purchase is the colorimeter sensor and a blank recordable DVD (total cost about $150 US).
Note on X-Rite i1 Display Pro III colorimeter and compatable software: Tom Huffman, creator of the ChromaPure software, posted the following information in another thread here on AVS just as the i1 Display Pro III was being released:
"I just had a lengthy discussion with X-Rite, and here's what I learned. There are actually 3 versions of this meter--ColorMunki, i1 Display Pro III retail, and an i1 Display Pro III OEM.
____________________________________________________________ ______
Press up, down, right, left, enter (press these buttons in this sequence and do it fairly fast). You may need to try several times to get the timing just right to bring up the service menu screen.
CALIBRATION TOOLS
- Colorimeter Sensor: Probably the most popular low cost, quality colorimeter sensor is the now discontinued Eye-One Display LT (often just listed at the i1LT) made by X-Rite. HERE is the manufacturer's link and HERE is the link for it on Amazon. The substantially more expensive Eye-One Basic Pro is a popular sensor (actually a Spectroradiometer instead of a Colorimeter) for professional calibrators. Another colorimeter of intertest to the hobbyist is the Chroma 5 (priced between the two Eye-one models described above). Finally X-Rite released in mid-2011 a new model colorimter called the i1 Display 3
(this sensor may also be called the i1 Display, i1 Display Pro or may in some cases be referred to as the i1 Display 3 Pro or i1 Display Pro III by some dealers for a calibrated version - so check the details before you order). This new low cost model is much more accurate than the i1 Display 2 series (e.g., Display 2 Pro and Display LT) that it replaces and is said to maintain accuracy better over time than the Display 2 or Chroma 5 series. Important - see the note below before purchasing this colorimeter.
- Colorimeter Software: A widely used free colorimeter software program is called HCFR Colorimeter. The new (2012) web site for an updated version of the HCFR software is HERE and the AVS Forum discussion thread is HERE. A number of companies sell commercial calibration software. CalMAN and ChromaPure are among the more popular alternatives. HERE is an article comparing HCFR (original version), ChromaPure and Calman software.
- Software Calibration Aid: An AVS Forum member (stereomandan) has prepared a very useful Excel spreadsheet that can be used as a companion to the colorimeter software. HERE is the AVS thread where you can download the Excel spreadsheet file and the instructions for using it.
- Blu-ray Compatible Calibration Disc: The AVS HD Calibration Disc (ISO file that can be burned on a DVD +/- R) is described and can be downloaded HERE. Once downloaded you can use a commercial program such as Nero or a freeware program such as IMGBURN, to create a playable disc by burning this ISO image file onto a blank DVD (-R, +R or RW as long as it is a disc type that is compatible with your Blu-ray player).
- Calibration for Dummies: General overview of display grey scale and color calibration is HERE
- More Tutorial Information on Calibration of Projectors: HERE is the link to the AVS calibration thread for some earlier Epson projectors that provides a lot of basic information in Post 1 that generally applies to the calibration of projectors.
- The ColorMunki and Display Pro retail are for the retail market only and are designed to work with the included X-Rite software for monitor profiling.
- The retail versions will NOT function in ChromaPure or any other vendor's software other than X-Rite. Only the OEM version will work because the code in ChromaPure includes a password for enabling it.
- The retail and OEM versions of the i1 Display Pro are otherwise identical.
- If you want to use this meter with ChromaPure, then you have to obtain the meter from ChromaPure directly, one of my partners (e.g. AVS), or another OEM vendor. Versions of this meter obtained in the retail market will not work."
- with an X7) so I'll take a look at it.
