bollundus wrote
This question was answered later in the thread by a poster Mannio1 suggesting he check his settings. He wrote:
I have the same issue except my projector starts out red then after several minutes and changing inputs it evens out, a bit. I thought it was associated with the machine warming up. It appears that is not the case.
The poster was referring to rgb and other color settings. I have been fooling around trying to get the color right with this issue active. Can someone tell me how to do a complete reset?
I then should take off the auto setting and find the correct color setting. I have two inputs going to the projector, HDMI and component. When I find the correct one I will enable it to user one and then user two?
Then when I select either input in future it should default to the correct user setting for the different inputs?
he X3 looks after turning in the first minutes has heavy green tint.
Within 10 minutes it is improving only slightly.
The Solution is to selecting a different preset, or a power cycle of the source. Now anything seems again to allow normal function. Even when you turn the originally(on start) selected preset is displayed correctly.
Overall, the Red has fallen sharply after 130h.
I had to recalibrate completely.
But the differences in the calibration are just peanuts compared this massive initial Green-Tint-Problem, which can only be turned off by switching the preset or, switch Off/on the source. Not very suitable for everyday use.
Could anybody has seen similar behavior? Does anyone have any idea which connected it?
Your heavy green tint issue solved by switching the preset or the source sounds like the wrong colorspace is selected. If your setting is on auto, try to cycle through the different colorspace options (YCbCr, RGB etc) until your picture looks correct.
I have light meter and colormeter (i1).
