Sorry for this probably dumb newbie question. Is it possible to do the calibration with the color meter about 6 feet away from the screen?
post #181 of 431
2/22/11 at 2:57am
I was in the same boat a few months ago and read the guides front to back. I had the Eye One LT1 and use Color HFCR for calibrating my RS50. The issue I ran into was meter was reading my red valus correctly so the resulting calibration was off enough that you could easily tell with the eye something wasn't right.
I borrowed an Eye One from a peer at work and had similar results measuring red. I decided to order the Chroma 5 Pro from Tom Huffman at Chromapure. He will calibrate a meter (Either an LT1 or Chroma 5) against a reference meter and creates an offsite file that you use with a license of Chromapure which is great calibration software. once you get familar with the basic, perhaps consider sending Tom your LT1 for calibration and a license of Chromapure standard. imo the cost is worth it because you will get better results with a calibrated meter. Check the site for prices. |
