- Hours: 752
- Delivery: Dec 8th 2010
- Screen size: 128"
- Throw lens/screen: 14' give or take a few inches...
- Natural mode
- Color space: normal
- Gamma normal
- High Lamp
- Iris fully open (0)
- I did a very quick calibration from white levels (using the Lumagen mini)
I did not do an ANSI reading cause I was running against the clock.
The reading at center screen shows 115 lux or 519 Lumens.
- Screen size: 128"
- Natural mode
- Gamma normal
- High Lamp
The problem is the OFFSET: you should NEVER increase it because it destroys the black level. The same with the GAIN: you can only decrease it which (usually) costs luminance.
