AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › JVC RS40/X3 Calibration Thread
JVC RS40/X3 Calibration Thread - Page 10
post #271 of 431
Hi,
I think it's not a peak but the average of nine measures on the screen, as square : left, center, right and up, center and down on the screen.
It could be an average of multiple projector, but I think, in most of case, measurements are for a single projector (I'm not sure but it seems logical to me).
post #272 of 431
I have updated Lux to Lumens Excel spreadsheet attached to Post #2 of this thread. You can now enter the projector-to-screen throw distance and the zoom ratio will be calculated. A zoom ratio = 1.0 corresponds to max. telephoto setting, which givens you the smallest possible image size. At the other zoom extreme, max. wide angle, the zoom ratio = 2.0 which gives you the largest possible image size. This zoom ratio calculator is only intended to work for the zoom lens used on the JVC projectors (RS40/50/60/X3/X7/X9). Note in the spreadsheet I only show the zoom ratio to one decimal place since this is only intended to be an approximation.
For those of you that use the spreadsheet, please include the zoom ratio when you post your projector's measured lumens.
post #273 of 431
If you are a CalMan pro user, you can download the latest CalMan beta that does direct control of the RS40.
Check the SpectraCal forums for the beta download link.
post #274 of 431
By "pro" do you mean expert or commercial? This seems really cool.
post #275 of 431
JVC workflow is currently only supported by the Commercial license.
But you can use the manual DDC control with the interactive add on
post #276 of 431
Hi everyone,
Apologies if the subject has already been discussed, I did a search and couldn't find any relevant post in this thread.
I have a question for those who have calibrated gamma on the x3/rs40 using the internal controls.
There is a problem with the gamma controls of the rs50 which is that when you adjust white at one level, it disrupts the greyscale at that level, which means you have to spend ages to correct both white gamma and RGB balance, going back and forth betwen the two.
I would really appreciate if someone could confirm whether the rs40 has the same issue or not.
If you are not sure, there is a very simple way to check for this. After you have set your gains for the color temp (say at 80 IRE) so that the RGB balance is perfect at that IRE level and the pattern looks grey/white with no tint, if you keep the 80IRE pattern on the screen and move the gamma white control at 80% (either up or down, please try both), does the white pattern change to something reddish, blueish or greenish, or does it stay white? If it stays white, the gamma controls work as expected.
I would really appreciate if someone could check this quickly next time the meter is out...
Manni
post #277 of 431
Th JVC workflow is included in the Commercial license but there might be a JVC add-on available for the Expert license, it's worth checking with Spectracal if you have an Expert license and are interested in the JVC workflow (which only works for gamma/greyscale as far as autocalibration is concerned, not for gamut calibration by the way).
post #278 of 431
Try the following:
1. Adjust contrast and brightness. Look for the values near 235. I had to reduce the contrast (-4), otherwise I got a color error.
2. Display a 100% IRE pattern. Use the GAIN controlers to adjust RGB to 100%. That's very important because it sets the white point correctly. You can also go to the service menu to do this.
3. Check brightness and contrast again.
4. Use the gamma equalizer to adjust the greyscale points from 10 till 90 IRE and the gamma. Yes, it is possible to calibrate the greyscale points (use RGB in the gamma equalizer) AND the gamma (use WHITE in the gamma equalizer) only via using the gamma equalizer.
Important:
- Do not use the offset controlers ! That destroys the black level
- Do not use the 100% RGBW-controlers of the gamma equalizer !
post #279 of 431
At the moment you can use the JVC workflow only with the commercial license. That info comes directly from Spectracal. Maybe there will be a add-on in the near future but that's not for sure.
post #280 of 431
Try the following:
Important:
Thanks for the 101 in gamma calibration - I agree was all this by the way - but I was not asking for the theory, I was asking whether moving the white gamma controls on the rs40 disrupts the rgb balance or not, as it does on the rs50. I only suggested 80IRE because that's what most people use for settings the gains and I wanted to keep it as simple as possible. I do calibrate the gains at 100 IRE, but thats not relevant here as there is no gamma control at 100IRE, the highest being 95. I don't have an rs40, only an rs50, so I can't try myself on the 40.
So, anyone has noticed this on the rs40, or are the controls working as expected, i.e. moving gamma white doesn't disturb the RGB balance at that control point, whether it is 80 or 90IRE?
post #281 of 431
I use the internal GAIN controlers for setting the 100 IRE white point; gamma and grayscale are done via my Lumagen Radiance. That does function very well.
But I asked a good friend of mine who owns a RS40 too. He calibrated his RS40 like the way I told you before. And no, there was no problem with the RGB balance vs. gamma: you can adjust the RGB balance with the RGB controlers of the gamma equalizer and the gamma itself with the W controler of the gamma equalizer. The W controler does not interact with the RGB controlers --> the deltaE values don't change after using the W controler.
post #282 of 431
Thanks, that's the information I was after.
This is good news for rs40 owners.
post #283 of 431
I am a little bit confused. The RS50/60 are using the same CMS for gamma / grayscale. But I have never heard anything about problems with the internal controlers. I know that there is still a problem with the gamut controlers of the RS50/60: if you use the internal gamut controlers of the RS50/60 "too much", you will loose the linearity of the gamut. The only solution at the moment is to use the CMS of an external video processor like the Radiance.
post #284 of 431
Thanks, but I am VERY familiar with all these informations. I am running the calibration thread for the rs50/60 on AV Forums and investigated these in details very early.
The rs50/60 do not have the same CMS as the rs40, as it is very limited on the rs40 and is only accessible in the service menu. The rs50/60 have a full internal CMs which doesn't track saturation properly, but it is possible to get excellent results with it if you know what you are doing and are NOT targetting rec-709 in order to get it. It is true that it is less easy than using an external processor like the lumagen. You need to aim for a slightly oversaturated gamut at 100% Sat in order to compensate for the undersaturation at 75% sat, which is not easy to do but again gives very satisfying results visually, which explains why rs50/60 users can be happy in this area when the unit has been calibrated by a competent calibrator.
The issues with the cms and gamma controls have been confirmed by Phil Hinton in his review of the x7 on av forums and aknowledged by JVC, who promised a fix a while ago, so it's pretty common knowledge.
The issue with the gamma controls on the rs50/60 are probably due to the fact that they are handled by the genessa chip in charge of the cms, 3d and gamma, which is not present on the rs40.
You should read the calibration thread on av-forums and the multi-part review of the x series from Ekkeheart at cine4home if you are interested in this.
In any case, I'm glad to hear that the rs40 doesn't have the gamma issues of its older siblings, thanks for the information.
post #285 of 431
Forgot to say, please note that on the jvcs, gamma is usually not controlled by the cms, as models without a cms (like the rs10, 15 or 40) have always had gamma controls.
post #286 of 431
Oh, I have read your thread at AVF And I also know Ekki from cinema4home ... he calibrated my RS40 6 month ago and I personally talked to him for many hours at the home cinema trade show in Karlsruhe / germany
Because of "CMS": IMHO a complete CMS consists of controlers for grayscale, gamma and gamut. And, of course, I know about the fact, that the RS40 lacks of a "complete" CMS: there are no controlers for the primaries / secondaries available. That's one reason I use a Lumagen Radiance.
post #287 of 431
Chromapure + VideoEQ + RS40
Until now, I have been dependent on the generosity of a friend to calibrate my projectors (previously an RS1 and now an RS40). Unfortunately, my friend has moved out of the area, so I have taken it upon myself to learn how to perform calibrations. My RS40 was exchanged for a replacement, so now I need to calibrate it. I had been using a VideoEQ and I have just purchased the Chromapure Software with the Chroma 5 meter.
After reading all the documentation and this thread plus spending a few hours performing various calibration steps, I am still having some difficulty trying to figure out how to use them together. If any of you are using these with the rs40 and are willing to answer some questions, please respond here or pm me. Thanks in advance.
post #288 of 431
I will be doing a CalMAN + VideoEQ + RS40 calibration in 3-4 weeks. Just waiting to get enough hours on the bulb. I'm pretty happy with everything after doing some basic adjustments, so a full calibration should make it exceptional.
post #289 of 431
RE: Custom Gamma RGB question
I have adjusted the "white" gamma to get a fairly flat line around 2.3 with Chromapure. I do not understand what pattern(s) I use to adjust the red, green & blue gamma within the custom gamma menu.
post #290 of 431
Don't you just put up the gray fields and adjust red, green, and blue so they are all 100% at each IRE level? Make sure you set your white level properly first.
post #291 of 431
I have been getting varying measurement results (luminance, gamma, grayscale) from one day to the next with the same settings on the RS40. As this is my first experience with calibration (Chromapure software with Chroma 5 meter) I thought it might be something I was doing wrong so I documented the results over 3 days with 3 different picture modes with no change in the RS40 settings. I sent the data to Tom Huffman (Chromapure) and after he reviewed the data, he attributed the variance to the instability of the RS40 bulb. Now that I know that it is not an operator issue, I will move on to the VideoEq to further improve the results.
post #292 of 431
Instability of the RS40 bulb ? How long have you calibrated your RS40 ? I did many calibrations on my RS40 within 60 hours. There was NO difference between the measurements ! BUT: you should ALWAYS wait for about 1 hour, BEFORE you start calibrating !
post #293 of 431
With the recommend settings for measuring lumens in this thread (Natural,standard,open iris,high lamp mode, etc.) and using the AVS disk to set contrast and brightness, I measured single center lux at 335 which using the calculator comes out to 1037 lumens bulb at 132hrs. JVC X3 is 14ft away from 106" screen. Hope it does not drop too much with more hours but happy I have a little headroom.
post #294 of 431
I know that it is really too early to be doing a calibration, but I couldn't wait any longer, so I did a "quick" calibration. For this calibration I adjusted the projector settings to get 100IRE as close to D65 and Gamma 2.3 first and then further dialed in the settings and adjusted the CMS with the VideoEQ. I should be able to leave the projector settings alone from now on and just change the VideoEQ as needed over time. I plan on doing a full calibration again at 50H, 100H and then every 100H after that. My hope is that I will be able to maintain a lumanance of 12fL in Normal Mode as the bulb ages by adjusting the Lens Aperture.
Calibration Equipment
Colorimeter: Spectracal X2
Software: CalMAN 4.2.2
Lux Meter: LX1010B
Screen: 106" Grandview White 1.0
Lamp: 30 hours
Throw: 12'
Seating: 13'
Lumanance(D65): 12fL
Zoom Ratio: ~1.9
Lux: 130
Room: Dark walls, white ceiling, medium carpet, black velvet on screen wall, no windows.
Lens Aperture: -12
Lamp Power: Normal
HDMI: Standard
Black Level: 0
Comments:
- Very happy with the results.
- The VideoEQ is really an exceptional device that makes adjusting any display very easy.
- I will continue to monitor my calibrated lux.
- Next step will be lowering the ambient light and reflections in the room.
CalMAN After AVFoundry VideoEQ Adjustments:
post #295 of 431
Originally Posted by Kelvin1965S View Post
I just wanted to comment about the use of 'Normal' gamma as a base: I don't know why it was called 'Normal' as JVC seem to have picked the worst curve possible to give this name. I've noticed many new owners seem to use this setting, but I can only assume it's purely because of the name, so they think it must be the correct setting to use...
Out of the box I believe A or B would be much closer to 2.2 to start with, though I've always used a default custom gamma of 2.3 myself as I prefer a slightly higher gamma in my room. Of course anyone that is going to calibrate fully would probably use a custom gamma anyway I guess, but the above is more for those who haven't got round to calibrating yet (or are waiting for the hours to build up first).
From Kris Deering's review of the X3:
A very complete Gamma selection menu offers several Custom Gamma Correction values, such as 2.2 or 2.3, that you can either use as set by the factory or tweak as desired. I found that the 2.3 Custom Gamma Correction tracked an almost perfect 2.2 curve, which seems to be a sweet spot for most rooms. It appears that the presets generally track one value down from their numerical Correction Value, so if you're looking for a 2.3, the 2.4 preset works; or for a 2.4, the 2.5 preset works, and so on.
Hi,
The reason that many of us rookies use the Normal gamma setting is because it is what JVC recommends, both in the owner's manual and in their FAQ.
I would be interested in hearing from others on the pros and cons of using the a Custom Gamma Correction value of 2.3 versus the default Normal Gamma.
Larry
post #296 of 431
Hi,
Larry
I am curious about this as well. I started out using the 2.2 custom setting (which it seems is closer to 2.1 from what I am reading here) then moved over to the "A" setting which is what I am still using. Guess I should try out the 2.3 setting since it is closest to 2.2.
post #297 of 431
You should use the custom gamma 2.3. But also this gamma equals to a power gamma of 1.9 till 2.2 - much too low in most parts of the 2.2 power gamma curve.
post #298 of 431
Hi Guys,
Here's a rookie question for you folks.
When we are comparing various preset gamma settings using normal content, without test equipment, what are we looking for? Improved shadow detail, more resolved highlights? What movie scenes are useful for comparison purposes?
Larry
post #299 of 431
For those of us using the AVS HD Calibration Disc (or any other calibration disc) for the test patterns when doing a calibration, there is potential source of errors that can be coming from the disc player. The "Secrets of Home Theater and HiFi" web site has now started testing Blu-ray players for accuracy in doing the converversion from the recorded 4:2:0 format on the disc to 4:2:2, 4:4:4 or RGB formats being output via HDMI. So far they have only tested Oppo BDP-83SE, BDP-93, and BDP-95 players and the Sony BDP-S570 player. The Oppo accuractly did the conversion but the Sony S570 showed significant errors. HERE is the link to the story. They indicate more BD player tests will be coming.
If you use a player that has errors, such as the Sony, it can produce a number of problems when doing the calibration. For example, when I first tested my RS40 I used a Sony S470 (which proabably has the same issues as the S570) and I found all of the preset gammas produce a curve that looked like an inverted 'U' and was especially off toward the white end of the grey scale. In retrospect, this may have been caused by the S470 rather the the RS40. So for now if you have a Oppo BD player, it appears there are no issues using it to play your calibration disc and if using a 2010 Sony model (i.e., BDP-x70 model) there are issues. Until we get more results for testing of BD players we won't know which other brands and models are accurate or have significant issues.
post #300 of 431
Comments:
Those are stellar results. Congrats!
Did you check how the VideoEQ tracks color saturation using the saturation window patterns on the AVSHD disc? Curious how well the CMS in the VideoEQ tracks lower saturations of the primaries and secondaries. They look excellent at 100% color saturation, but are you able to show how they do at 25%, 50% and 75% saturation? I'm assuming the VideoEQ will handle these patterns just fine, but I'm just curious. Hmm....
Dan
