Once I get more hours on the bulb I will do a more detailed calibration. With the VideoEQ I should be able to get the gamma better. I also plan to try out different gamma curves. I can store 4 presets, so could easily have 2-3 different curves for different material.
CalMAN 4 can only do 100% saturation levels, but I know that they are working on adding that feature. I need to look into calculating what the other saturation levels should be and testing them manually.
I believe that the VideoEq just assumes that everything is linear from 0-100% saturation levels.
