I already posted this in the official thread, but it's better to ask it here
after 461 hours on my second lamp I decided to buy light meter and measure the lumens using the center screen method on the white background in the service menu. Since this is my first projector, I really appreciate your input whether the below results is acceptable or not:
- animation preset
- contrast 8
- brightnes -5 (hdmi enhanced)
-color\ int 0
-color space wide1
- color temp 8000
-aperture 0
-calibrated using WOW disk
- screen is 114" with 1.3 gain (Da-Lite) with through distance of about 135"
-Lux 187/Lumens 670 in normal mode
Is this is acceptable? also, for a healthy lamp, will the brightness stabilize at this level?
thanks and appreciate your advice
- animation preset
- contrast 8
-color\ int 0
-color space wide1
- color temp 8000
-aperture 0
