AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › JVC RS40/X3 Calibration Thread
JVC RS40/X3 Calibration Thread - Page 3
post #61 of 431
Originally Posted by Lawguy View Post
Here is what we got for the RS40's gamut on Natural (Normal):
Is this just a straight shoot of the Natural mode or did you have to adjust color/tint controls to tighten it up? This looks a lot better than User 1 can obtain or even what I've measured with the Film mode.
post #62 of 431
No adjustments at all. I did change the color space from wide to normal though.
post #63 of 431
Interesting. I will have to shoot mine tonight in that mode and see how it looks. I am getting a Radiance Mini in tomorrow for even more fun!
post #64 of 431
Originally Posted by Ron Jones View Post
I'm not familiar with the specific set of controls your Onkyo offers. However, it sounds like they may be limited to only grey scale and gamma calibraton and not gamut (color points - saturation and hue for each of the primary and secondary colors). Since the RS40 does have controls to calibrate the grey scale and gamma there may not not be any advantage in using the Onkyo, especially since I assume it doesn't support HDMI 1.4 and thus could not be used to make adjustments to 3D video (this is the one mode where the RS40 will not let the user adjust gamma).
Hi Ron,
Thanks for the response.
Here's a list of the available settings:
Resolution
Brightness
Contrast
Hue
Saturation
Picture Mode (Auto, Video & Film)
Edge Enhancement
Mosquito Noise Reduction
Random Noise Reduction
Block Noise Reduction
Gamma
Red Brightness
Red Contrast
Green Brightness
Green Contrast
Blue Brightness
Blue Contrast
The current Onkyo preamplifier, the PR-SC5508, has this ISF video calibration feature and HDMI 1.4. I might consider upgrading to it for some other enhanced features as well as switching 3D video sources.
Larry
post #65 of 431
Originally Posted by LarryChanin View Post
Hi Ron,
Resolution
Brightness
Contrast
Hue
Saturation
Edge Enhancement
Gamma
Red Brightness
Red Contrast
Green Brightness
Green Contrast
Blue Brightness
Blue Contrast
Larry
This appears to be similar to the calibration adjustments offered by the RS40 itself. The Red, Green and Blue contrast and bightness are probably equivalent to the RS40's red, green and blue gain and offset adjustments and these are for adjusting grey scale.
post #66 of 431
Glad to have Lawyguy come by. He's a stand up individual
That graph was with the lens aperture set to -3 with 10 hours on the bulb.
I didn't get a lot of time on it today but hopefully tomorrow when my mount final comes, I'll get some proper time in.
I did take some measurements but I think an object near the pj skewed the results so I'm not going to post those.
post #67 of 431
I have done measurements for both Film and Normal (both set to Standard vice Wide) and neither are even close to the measurements I've seen from you and Tom (he did Film I believe). I am using Calman Pro with the latest FW and a PR650. It would seem that the units you both have used track MUCH closer to REC709 than the units I've seen (both RS40s and 50s), though the palette I am seeing on the 40 I have on hand is much better than most PJs I see with presets out of the box.
post #68 of 431
I just picked up my new X3 and noticed in the service menu that it has new firmware: 2010.12.14.2-O
I was under the impression that 1.2 is the latest one (which is the one you can download from JVC website). Does anyone know more about this?
post #69 of 431
What I saw looked really good. I think the RS40 is definitely sharper than my RS20. That was the biggest difference that I saw.
Hi Lawguy. Did you change the sharpness and Detail Enhance control to 0? I think it is at 25 by default.
post #70 of 431
We also messed around with the FPD Benchmark disk and what the CMD did to motion. It was nice to see that the girl in the hammock scene no longer has the motion induced contouring issue. For that 1080i material, I think that the second DFI mode looked best. But, there was too much flicker for me with 1080p24 material. I think I would stick to plain old 24fps with no DFI or FI for movies.
Did you notice any of the color flashing or fringing reported by others with the DFI modes?
post #71 of 431
Buttabean will have to let us know what those are set at. We did adjust them.
post #72 of 431
Yes to both.
Joe will chime in if he disagrees, but at the time, we both thought that: Color fringing is much less on mode 2 than on mode 1. Mode 2 is overall better than mode 1. Unfortunately, Mode 2 is dimmer than mode 1.
We spent a bit of time using the FPD benchmark disk and looking at motion on the girl in hammock pattern and the girl on a swing pattern. This is a 1080i disk.
With all CMD modes off, the RS40 is better than the RS20 because there is no longer much, if any, motion induced contouring. That is not to say it looked good. It was just better than the RS20. On mode 1, the red/green fringing was obvious, particularly on the girl's nose in the hammock clip. I have to say that even with the fringing, it looked tons better than with no CMD mode on. I don't know for sure because we did not watch much real material at the time, but I think I might accept the fringing as the price for better motion on sports. Mode 2 was better but not as bright. So, we have choices to make about which compromise is best. No perfect options, unfortunately. I don't care for frame interpolation at all and would not use it.
It takes time to cycle through each of the CMD modes. This makes a direct comparison difficult.
I am not sure that I would use DFI for 24p content. Flickering was pretty bad, but I think at that point we had focused on mode 2. Mode 1 might be better. I might try to sit through a whole movie with DFI and see if I get used to it.
post #73 of 431
One other calibration facts on Joe's unit. Unlike any other JVC that I have ever calibrated, when working on greyscale, the RS40's lamp had plenty of Red. Blue appeared to be the color that was most often deficient. This may be because of properties of the new lamp or it may change over time.
post #74 of 431
I'm seeing the same thing with mine. First PJ I've ever measured where there is an abundance of red and blue is the color that is lacking. I'm just over a 100 hours and getting the same thing.
post #75 of 431
My RS40 was closer out of the box than my RS50 is, I am guessing something isn't quite right with my bulb, my RED is down considerably since out of the box and now with about 60 hours. You don't need a meter to see it.
I had to pull down the blue and green to compensate. I am also concerned my meter isn't entire correct, it's the inexpensive Display LT and it could be off by a mile. I am considering sending it to Kal for a calibration or possibly considering the Chroma 5 Pro as a replacement.
post #76 of 431
I found out how poor my i1LT was when I rented an i1Pro recently: The 'perfect' i1Pro calibration (with deltaEs of less than 1.0) measured 7.0 or greater deltaEs with the i1LT. The only thing I found was that it was still good for measuring gamma (it measured pretty much the same as the i1Pro).
post #77 of 431
Yea, even inexpensive colorimeters measure luminance quite well.
post #78 of 431
I have the Same issues with my bulb!!! 40% off in only 200h! I also have to compensate with Blue & green and I measure this with i1pro!
post #79 of 431
My red is down compared the blue and green, but my max lumens output still measures 1100 after 165 hours. So I don't agree there is a correlation between red drop and a fault with the bulb.
Normally a UHP bulb drops red first. There seem to be some who are finding red holding up better than expected, but every bulb is different.
post #80 of 431
What is your lumen output calibrated but iris wide open?
To others, are you measuring your light output with a light meter to get the lux and converting that to lumens or are you using your colorimeter?
post #81 of 431
I would agree that the color points look a lot closer than I measured in either Film or Cinema mode (User 1 mode appeared to me to be very similar to Cinema mode) and with the color space set to Standard. Those are the only ones I measured since I assumed they were probably the more accurate, but perhaps Natural Mode with normal (Std.) Color Space is the best after all for the most accurate colors. It's certainly worth a few more of us checking it out on our specific RS40's to see if it generally holds true or if the RS40 lawguy measured was a one-of-a-kind exception.
post #82 of 431
Calibrated, iris wide open, bulb high = 590 lumens
THX is 650 lumens
post #83 of 431
Originally Posted by TomHuffman View Post
In my opinion, this should be one of the shortest calibration threads on AVS. The RS40 performs remarkably well out of the box. Both the gamut and gamma were very close to ideal targets and the grayscale was off by only a little.
All measurements were taken in the Standard Mode.
The only adjustments I made were:
  • Adjusted the white point using the the available gains and offsets with one additional tweak at 10% stimulus using the custom RGB gamma control.
  • Adjusted the main Color control up a few ticks to improve the color accuracy.
  • Put the HDMI mode into enhanced and then adjusted the brightness control appropriately.
  • Adjusted by 1 tick the convergence control for blue. After this, the convergence was about as good as it gets, though the inter-pixel clarity was not as good as DLP, which is to be expected.
That's about it.
When new, this PJ was bright enough for a 110" StudioTek in the low lamp mode, but most will probably want to put it into high lamp mode and then adjust the iris as the lamp ages. I got about 650 lumens in the High lamp mode.
Here's the setting I found on this unit (per Tom's original config):
Contrast 12
Bright -7
Color 7
Tint 0
Color temp -> Custom 1
Gamma -> Custom 1
-> Custom 1:
Red -13
Green 0
Blue -7
Offset Red 2
Offset Green 0
Offset Blue -1
post #84 of 431
Lawguy - thanks for posting the CIE chart and measurements. Very interesting. There was some chatter elsewhere that the service menu in the RS40 can be used to tweak the colors somewhat (poor man's CMS). Anyone know if it can bring red closer to a dE of 5? I like the position its in currently (with your measurements) but would want to desaturate it just a bit more.
post #85 of 431
I did not play with the service menu controls.
post #86 of 431
I've been trying to dial in the picture on the rs40 for a while now and have not been happy. My last two projectors I was able to get the picture where I was happy with a mix of using the calibration disc in combination with others posted settings. I realize that not going to be accurate but I was able to get what I considered a good picture.
I've tried so many different combination's with the rs40 and either have too much black crush, raised black levels and/or clearly inaccurate colors.
For an amateur like myself should I try and buy calibration tools or just pay a calibrator to come in and dial it in after about 100 hours of burn in?
Frank
post #87 of 431
The X3 looks after turning in the first minutes has heavy green tint.
Within 10 minutes it is improving only slightly.
The Solution is to selecting a different preset, or a power cycle of the source. Now anything seems again to allow normal function. Even when you turn the originally(on start) selected preset is displayed correctly.
Overall, the Red has fallen sharply after 130h.
I had to recalibrate completely.
But the differences in the calibration are just peanuts compared this massive initial Green-Tint-Problem, which can only be turned off by switching the preset or, switch Off/on the source. Not very suitable for everyday use.
Could anybody has seen similar behavior? Does anyone have any idea which connected it?
post #88 of 431
Frank
What kind of adjustments are you making?
From the kinds of problems that you are describing, I would wager that you might have the wrong HDMI setting and/or brightness set improperly. Either of these will crush blacks. Download the AVS calibration disk. It is easy enough to use the basic test patterns to determine if these things are set properly.
For your color issue, use the Natural (standard, not wide) color preset. This seems to be closest to accurate. Also, resist the temptation to play with the RGB sliders in the greyscale controls. You will surely do more ham than good.
Keep everything else at its default. These things are close to accurate right out of the box,
post #89 of 431
Your heavy green tint issue solved by switching the preset or the source sounds like the wrong colorspace is selected. If your setting is on auto, try to cycle through the different colorspace options (YCbCr, RGB etc) until your picture looks correct.
post #90 of 431
I've messed with everything...I'll reset and use the AVS calibration disk with your suggestions to see if that improves anything.
