also, as most of us probably installed with IDE parameters, ssds work much better with ahci but win7 has it disabled. here's how to fix that.
AHCI (Advanced Host Controller Interface) enables native command queuing and hot-plugging through SATA host controllers (Serial-ATA) for your hard drives. In many scenarios it enables more efficient multi-tasking. Vista was the first Windows OS to support AHCI out of the box, where as Windows 7 does the same. But an issue with AHCI is that if you install the OS without enabling AHCI in the BIOS, enabling it after installation will render your OS unusable. This is because Windows disable the AHCI driver since it is not needed during the installation.
There is one way to fix this, although you need to have knowledge of registry editing. The detailed steps from Microsoft are as follows:
To resolve this issue, enable the AHCI driver in the registry before you change the SATA mode of the boot drive. To do this, follow these steps:
Exit all Windows-based programs.
Click Start, type regedit in the Start Search box, and then press ENTER.
If you receive the User Account Control dialog box, click Continue.
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINESystemCurrentControlSetServicesMsahci
In the right pane, right-click Start in the Name column, and then click Modify.
In the Value data box, type 0, and then click OK.
On the File menu, click Exit to close Registry Editor.
After this you'll have to restart your computer, go to BIOS and enable AHCI. When you log in to Windows again, you'll notice the installation of drivers for AHCI. Another restart will be required to finish the driver installation.
