Hi everyone.
I hope this is the right section for this. My theater is my living room and my projector hangs about 3-4ft from the ceiling (high ceiling). Can't mount it higher or lower due to the projector not having any sort of keystone adjustment.
The projector has 5 fans in it and sounds like a jet engine mounted to a freight train. I read some other threads on hushbox design and tried my hand at my own design. This design is somewhat "universal" in that when the bulbs (yes, bulbS...this projector has two) eventually go out, I'll just buy a new projector instead of replace the bulbs and I want the new one to work in the same hushbox.
Here's some sketchup drawings of the design I came up with:
The air will be pulled into the right channel and exit the left side of the box since the rear left side of the project is where it's exhaust is.
The air channels will be lined with a sound damping material. The fans are 120mm computer fans and will have a trim pot to adjust the speed of them. The overall dimensions of the box are pretty large but the projector itself isn't small to begin with.
Thanks in advance!
Thanks in advance!
