Originally Posted by
havasuvideo
What I meant by motion is CMOS jello effect. The 3MOS is just better able to handle fast moving objects.
Why? Because there are fewer photosites to scan within the same timeframe? Maybe, if they are scanned simultaneously. Maybe this is another reason Canon has returned to 2MP sensors.
havasuvideo
The only reason the Sony would need more Mb/second for the resolution is noise or artifacts. It's got something extra tagging along. It remains to be seen what it actually is.
I still don't get what you are talking about. Most people admit that Panasonic's 17 Mbit/s AVCHD is acceptable at best, while Sony's 16 Mbit/s looks much better, which means that Sony might have a better AVC encoder (its MPEG-2 encoder is a totally different animal). Sony can go up to 24 Mbit/s in regular AVCHD mode and it is nose to nose with Panasonic in 60p mode (28 Mbit/s).
havasuvideo
Not sure what ergonomic problems you have with the Panasonic. Sure, it's small, but I use it on a mono-pod-not a problem. The touch screen and the controls are NOT user friendly. And, the EVF is all of about useless.
I mean the single Super-Duper Control button that controls everything and does it poorly, resetting your exposure settings when you do not want it.
havasuvideo
Why do you think little pocket sized camera's have 15 mega-pixel sensors?? Because they're tiny sensors. While a DSLR 10 mega-pixel camera will kick it to the curb, quality wise.
Sorry, I did not get this either.
havasuvideo
But, if 60P isn't your thing, then go with what works best for you. I have plenty of frames to get to 24P, and can do that at normal motion, with software conversion.
You cannot do this without dropping and blending frames, and the result will never look as clean as true 24p recording.
havasuvideo
Also, the Panny 1080/60P video is a relatively short GOP, with I-Frame.
What is the length of GOP in 60p mode? Is it different from the regular 15 frames? And sure each GOP has an I-Frame, so I don't get your point about I-Frame.
havasuvideo
That is outstanding for such a small camcorder, and it allows the stream to hold a lot of information for it's size.
What is the relationship between camcorder size and stream type?
havasuvideo
I forgot to ad that the Panny has an F/1.5 lens, which is equivalent to about T 3.0...in a camera this size, that's outstanding!!!
Side by side, the TM700 is about half a stop slower than the 2006 HDC-SD1 according to my own testing.
