AVS › AVS Forum › 3D Central › 3D Source Components › Acerh5360 Projector and PPV 3D
post #1 of 10
will i be able to use the Acer h5360 to watch PPV 3D movie titles?. i cant test it as i apparantly dont have the correct HDTV box from my provider.
But before i purchase the new one, will it even work?
Or do i need to wait for the 3D-XL unit
Cheers,
R.
post #2 of 10
Unless you want to build an HTPC, you will have to wait for the 3DXL.
post #3 of 10
I have a htpc, but how is that going to help with ppv from my tv provider?
post #4 of 10
I am curious about this as well.
I wantto do everything from my HTPC.
post #5 of 10
You two will need to get an AVER Media HD DVR capture card. A program called stereoscopic player makes it work. Use the live view feature on the Aver Card.
post #6 of 10
Will this work with the nvidia 3d kit, it also has a 3d player.
I have the acer 5360 and all I really want are the PPV 3d movies from Comcast to my computer.
post #7 of 10
Yes... It should work. Others report it worked well.
I can't get the ave card to work reliably for me period though, just to warn you. It's the card itself. On every MB or system I try it on. I get either the GPU working reliably or the aver card working reliably but never both working reliably at the same time.
post #8 of 10
Thanks for your help John. All is working well.
post #9 of 10
The aver card is working very well thru HDMI from the DVR to the card. The 3d, comcast, looks very good as well. I downloaded the 3d software from the aver site and it worked right a way. I can't record from the computer, so I still record from the dvr.
I am now set up for everything I need to enjoy 3d from just about any source I choose.
post #10 of 10
which specific AVERTV card are you all using??
  Back to Forum: 3D Source Components
