post #1 of 1
I have two sony projectors.. A Sony Qualia 004 and a Sony hs51..
Is there anyway I can switch one of them into a different power on/off IR code set so that I can turn them on/off independently? They are both on the same IR network.. Also, The qualia's IR reception is not very good.. What's with that? Any work arounds? I used to have an external IR receiver which could be plugged in to my old sony CRT.. I threw it away.. I wish I didnt.. I am being forced to use the IR mini emitter for the qualia..
