AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Best 3D Projector under $3000?
post #1 of 21
Hello guys,
I want to buy a projector with 3D built-in that is under $3000. Can someone one please help me?
Thank you.
post #2 of 21
you need a few more details like if 1080p is requirement if it is your budget is not enough. if 720p is ok are you using htpc for source?
post #3 of 21
I see. Well, the only requirement would 3D. So, it would be the best projector I can find for $3000 or under that has built-in 3D.
post #4 of 21
what are you using for source of 3d
post #5 of 21
The cheapest 1080p 3D projector right now, I believe, is JVC's RS-40 and it's around $3,500 on a power buy, which by now may be over. It regularly in the $4,500 price range.
If you know your way around a PC then one of the 720p 3D DLPs is your best bet and IMO, by far the best value out there - amazing 3D with no ghosting.
This fall (2011) Panasonic is supposedly releasing a 3D projector and it may be in your price range if you're willing to wait.
I've lived with 3D on a 120" screen for the past couple of months and I'm completely sold. This is the biggest improvement to date in my HT!
post #6 of 21
Still no projectors with built in 3D for under $3,000. We must either rig up a 720p "3D Ready" projector through a HTPC, or spring for a 1080p projector at significantly greater cost. There was an announcement of a 1080p DLP projector from Sharp that should be available before too much longer, but last I saw the price was not set.
post #7 of 21
Price of the Sharp 3D projector is $5,000. It's the cheapest 1080p pj so far (except for the RS-40). Those 720p 3D DLPs are nothing short of amazing in 3D.
post #8 of 21
How about the Benq 600+?
I've heard it's 3D capable, and it's under $700.
post #9 of 21
That depends on how you define "built-in" - it accepts 3d from computers, but will not accept hdmi 1.4 inputs. In that way, it's just like the 3d projectors listed above (optoma HD66/HD67/HD67N/PRO350w/etc, Acer H5360, Viewsonic something-I-can't-remember); 720p, 3d ready, but for hdmi 1.4 you'll need a converter like the 3d-xl, 3d-gamer, 3d-theater, radiance mini-3d, or the viewsonic 3d box I can't remember the name of (why I can't remember viewsonic model numbers... )
All of them have pretty similar specs, and all are in the 500-700 range. The boxes vary widely in price, though ($200-$1300)
post #10 of 21
Does this mean that 3d dvd players won't work?
Just starting to look for 3d equipment..
post #11 of 21
Will the 3D-XL require an emitter with a Acer H5360 ? or just glasses?
post #12 of 21
From my understanding, just glasses. i have 4 UC's on order and am waiting for an Acer/Optoma review before i splurge.
Remit
post #13 of 21
So passive glasses or active ?? Does it matter?
post #14 of 21
The 3d-xl gives you a bunch of different configuration options. There's the dual-projector vs 1 projector thing, but even beyond that there are several options for glasses.
-Easy: just get DLP link. Downside, you have to sync them sometimes when you start.
-little bit tougher: get a VESA compatible emitter and matched glasses (ie, samsung emitter/glasses). Harder and more expensivebecause you have to have the emitter in the setup, but it gets rid of the need to sync
-More advanced: Passive glasses. You'd need to get one of the active polarizers icester sells to mount in front of the lens, the run a sync wire to the vesa port on the 3d-xl. Then you'd need a silver screen. But the upside is you get to use MUCH more affordable (<$10) glasses!
post #15 of 21
Lots of options........now to do 2D to 3D upconversion.......will that only work going the HTPC route? And how good is that? Does it depend on the movie?
I appreciate any responses................
post #16 of 21
I have only converted a couple of dvds from 2d to 3d but some looked good some didn't seen to change much. I only watched a few minutes of each movie so not a real good test. PDVD10 only up converts dvds also. Not blurays. 3d rocks. I just had friend over and he was blowen away.
post #17 of 21
Thanks guys.
I have an infocus screenplay 5000 for like 4 years and it has been awesome!
I got a grey screen, a playstation 3 and a samsung sound system with blu-ray player.
Now I would like to upgrade my projector to 3D. Can I buy a 3D box for my screenplay? and then wait for 3D projectors to lower their prices.
post #18 of 21
Yes, it means that to get any of the 720p 3D ready projectors to show 3D, you will also need either a PC equipped with the right video card and drivers and player software, or one of the upcoming "boxes" like the Optoma 3D-XL. Projectors do not yet have anywhere near the degree of signal processing and converting that the 3D TVs have in the store. However, getting 3D on a big wide screen is worth the trouble.
post #19 of 21
Where's the link to icester polarizer? Does this config need 2 projectors/3d-xl boxes?
post #20 of 21
If you want to do 3d the proper way can you do it for Under 4000
when you figure in 4 pairs of glasses...?
I for one am passing on 3d till it gets more main stream,
I think to many changes are coming to that aspect of the market to make it main stream...
post #21 of 21
Well I just pulled the trigger on an Acer H5360............newegg.................499.00.......thought that was a good deal............and seeing that it is time for a new pc..........I am configuring that now.............any thoughts on that guys for this 3D adventure.......I sure appreciate your imput
