Here is a nice dust precaution I picked up from DIY channel, a zipper you can mount on visqueen, I think I used 4 mil. A god send when sanding the mud.
I framed in the riser, I went with hungers because I was going to mount the buttkickers in the riser, but..... I changed my mind. I'm just going to mount the BK's in each chair. All well, I kinda want an active riser
You will notice the nemesis of my HT build, that damn red pole. All well (again), if I would have built my room to avoid the pole, I would have lost use able space in the basement.
The stage, how do you guys like my design, it might catch on around here
I used Google Sketchup to figure out the arc.
I'm turning and burning!
