AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Help Setting Up Integra DHC-80.2 With HTPC
post #1 of 3
Hi everyone,
I'm looking for some help resolving a few problems that I'm having setting up my new Integra DHC 80.2 processor.
I recently purchased the Integra DHC-80.2 processor to replace an Integra DHC-9.9 and I'm having a couple of issues setting up the DHC-80.2 with my HTPC that I didn't have with 9.9. I simply unplugged components from the 9.9 and then plugged them in to the 80.2.
I'm having the following problems.
The first problem is, when the HTPC is starting up, the Integra looses the video signal just after the Starting Windows screen that shows the 4 colored shapes flying in has finished. In order to restore the signal, I press the setup button on the Integra's remote, let the setup menu open and then exit the setup menu. Likewise if I switch the input source to BD (or other) then back to PC it restores the signal. The HTPC is connected via DVI out to HDMI in on the processor.
The second problem I have is, when playing 2 channel pcm audio, the Integra looses and gains the audio signal sporadically. As it does this the processor makes a clicking sound as it switches between having a signal and no signal. The HTPC is connected via optical s/pdif to the processor.
My setup consists of the following components:
-Integra DHC 80.2 with current firmware.
-HTPC is running Windows 7 Home Premium edition.
-Soundblaster THX Certified X-Fi Extreme Gamer soundcard with current drivers installed.
-Nvidia GeForce 9500 GT graphics card with current drivers installed.
-Foobar2000 or XBMC applications for playing audio. Both apps are most current version. Using WASAPI via s/pdif for audio output.
-Epson PowerLite Pro Cinema 1080 projector connected via HDMI.
-Emotiva XPA-2 and XPA-5 amplifiers connected via XLR.
-Pace cable/DVR connected via HDMI (no issues).
-Pioneer Bluray connected via HDMI (no issues).
-9 speakers and 2 powered subs.
Also, I tried connecting my laptop computer and have the same issues.
Any help would be greatly appreciated.
Daren
P.S. I've also posted this on the Integra DHC-80.2 thread.
post #2 of 3
I use a pc with the 80.2 with no problems-video skype a lot. Espn 3, foobar etc.
I put the dvi from my nvidia 8600 to my kuro 151 -setting the KURO for normal not pc use.
I also put the audio output from my xmeridian via optical spidf in to the Integra assigining it to the CD source.
I have made sure the nividia has the latest software and the the pc is outputting HDTV (1080i)at 60 hz.
windows 7 professional 32 bit.
This works for me.
Sounds like there might by HDMI issues with your setup.
post #3 of 3
Has anyone tried directly connecting the videocard's HDMI to the receiver?
I am considering to get a DTR-40.2, and I am afraid I will run in similar problems the op is dealing with.
My previous Onkyo 608 did this to me. I could endure the clicking sound when the format changes, but sporadically losing the signal stream is very annoying.
I use a nVidia GTX 460 for HDMI output to the receiver.
