I have a 50" Panny Viera Plasma (TH-50OX80U) purchased from Costco a year ago. I have it set up in an outdoor living area in our backyard. A guy doing some work on the house noticed the screen had gotten dusty and decided to clean it with Windex.
Before he realized what he was doing he had taken off 4-5" square section of the AG coating from the center of the screen. Very noticeable and very bad. I decided to have him keep rubbing and remove the entire coating. The picture looks fine in the dark but as you can imagine in an outdoor environment the glare has gone from marginally acceptable to completely unacceptable during daylight hours.
I am looking at the option of putting on an after-market anti-reflective coating similar to what you see for laptops, iPads, etc. Any thoughts on this approach? The NuShield product looks best so far. (Sorry, being a Newb member I can't post the link.) Is this something you would recommend for this type of use? Any other ideas or suggestions? Your time and help is appreciated.
John
Before he realized what he was doing he had taken off 4-5" square section of the AG coating from the center of the screen. Very noticeable and very bad. I decided to have him keep rubbing and remove the entire coating. The picture looks fine in the dark but as you can imagine in an outdoor environment the glare has gone from marginally acceptable to completely unacceptable during daylight hours.I am looking at the option of putting on an after-market anti-reflective coating similar to what you see for laptops, iPads, etc. Any thoughts on this approach? The NuShield product looks best so far. (Sorry, being a Newb member I can't post the link.) Is this something you would recommend for this type of use? Any other ideas or suggestions? Your time and help is appreciated.
John
