Iusteve,
Thanks for the compliments!! My original intent with the Birch inset was to dye/stain them black so that you could see the grain and the rest of the column was to be black as it is. I actually spent a lot of time selecting which section of the birch to use on each face to have the grain look how I wanted it. When I tried to do the dye I had two problems... #1 it took a lot more of it than expected and it is not cheap, and two the final result had a purplish tinge to it and a faded look. I probably could have spent more time to try and make it work and learn more about dyeing and staining, but when I brought the dyed column into the room I found that do to the dark color scheme I have chosen it was virtually impossible to see the grain. Soooo.... being as you could not see the grain I realized that I might as well just paint it. If I was doing a lighter color room I think the birch would have looked great as just a natural color. I consoled my self with the fact that had I known this was how I was going to do it from the beginning the only thing I would have done differently is used mdf for the facing and the cost was about the same, so all I lost was effort. Actually I think using the birch made the columns stronger so that is good. I love the sconces, found them at Lowes about a year ago and ordered them up for fear they might be discontinued before I was ready for them... good foresight on my part as they were and I would have been so bummed!! As soon as I get the rest of the columns up I will wire in the Grafik eye and get some lighted shots. I am really looking forward to controlling the lights with the Grafik eye and Irule.
