AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer VSX-1120-K
Pioneer VSX-1120-K
post #1 of 6
Anyone has the receivers and if so could you tell me if it passes audio and video through hdmi like the 819 does?I'm looking for a new receivers been reading up on this one and hear alot of great things about but can't find any info if it passes the audio through hdmi i don't wanna make it where i have to use opictal cable just to get audio and hdmi for video.
post #2 of 6
HDMI pass through has been extensively discussed on the 1120 Owner's Thread -- 1120 Owner's Thread
There seems to be a fair amount of "it depends" when determining whether or not it will work--mostly related to the components involved in the HDMI chain. If you have the 819 passing through, then I would guess you wouldn't have an issue with the 819.
post #3 of 6
Actually, I think he was referring to simply passing audio along with video to the tv speakers during normal use, which is a slightly different question and function than "standby hdmi passthrough."
If I'm correct, then the OP would simply need to set the hdmi to "through" by using the "AUDIO Parameters" function on the remote while that particular input is selected, and the receiver itself is turned ON. Doing so would route both audio and video to the TV.
OP, did this answer your question?
post #4 of 6
I'm confused i'm try to explain better my setup now
Anyways i have the vsx-819
I have 1 hdmi going out to the tv
2hdmi is for my u-verse box audio/video
3rd hdmi is going to the back of my ps3 for it's audio/video
i want to know will this setup work when i get the 1120-k
post #5 of 6
Absolutely, yes.
post #6 of 6
Thanks man that's all i needed to know
