Hi,
I am trying to connect my computer with a Samsung Led 5 series tv with a DVI -> HDMI cable.
I have put the HDMI end of the cable in the first HDMI port of my tv (as explained in the manual). I start my computer, I can see the booting screen and windows (xp pro) that is loading. But after that my tv shows a message "1280 x 1024 @ 75 Hz" and then the tv goes black with another message "resolution not supported".
I'm wondering what the problem could be. (obviously the resolution, but I know the card supports 1980 x 1080 (through VGA)). Also I don't know how to change the resolution when having a black screen. Can I just change it with remote desktop?
1] I don't believe the first HDMI port is damaged as my digital receiver was connected to that port before.
2] I don't believe the cable is damaged as it worked on another tv of mine (samsung lcd le32r8 series)
Thanks in advance,
Mathew
Thanks in advance,
Mathew
