AVS › AVS Forum › HDTV › HDTV Technical › The Bachelor - blurry then clear then blurry
post #1 of 2
I watch DirecTV HD on a 106" screen via projector. Last night we were watching The Bachelor. Some scenes were extremely blurry to my eye. Then some scenes were razor sharp? Is this just life at 106"? Am I just seeing imperfections in the source material that has been there all along? This is my first projector so I don't have alot to go by.
post #2 of 2
Without knowing what station you're watching or city you're in, it's hard to say for sure, but the ABC stations received by the majority of people in the country are overcompressing the broadcast to make room for additional subchannels. Most of them are running encoders that will dynamically shift bits between the different channels as needed, so if the other programming hits a high motion scene it can rob bits from the primary channel to compensate.
  Back to Forum: HDTV Technical
