AVS › AVS Forum › Audio › DIY Speakers and Subs › Anyone have a Dayton SA230 amp?
post #1 of 7
http://www.parts-express.com/pe/show...number=300-813
Saw this at PE, anyone have one? Thinking this might be a cost-effective option if you don't want/need a plate amp. No reviews yet so I thought I'd toss it out here and see if anyone has any info.
post #2 of 7
I suspect that it is a new amplifier. I purchased two PE plate amplifiers in the last 14 months and have never seen this model (and I looked at all the PE amps).
http://www.parts-express.com/pe/show...number=300-805 - their 240w at the ~$100 sale price appears to be more cost effective than the above 230w amp at ~$220.
post #3 of 7
It has a lot of nice features you don't have on most of the plate amps. However, unless it's a typo the rated THD is a whipping 1%, which is ten or more times what one would expect.
post #4 of 7
i had two powering two THTLP's. perfect for that aplication IMO. the power LED is VERY bright though.
post #5 of 7
Thanks for the info.
Re the LED pilot, take a felt tip pen and mark the LED. You might need to let it dry and then reapply. It won't blacken it out but it will substantially dim it. That's a lot easier than trying opent he box and solder a small resistor in series or fitting a a piece of tape etc.
post #6 of 7
post #7 of 7
i put tape over it when i had them . they were sold with the THT's
