Originally Posted by Kurtis Bahr
Take an ohm meter and measure the CLD-79 output. you need to measure the center pin to the ground. It should read around 4.0VDC when a LD is playing and near 0.2VDC when paused or not playing. Also the Lexicon has some selections on the front. One of them is a bias to match the LD player differences. I found it didn't make a difference with my AC-3 addition to my CLD-97 but you never know.
Finally got around to measuring and did get just over 4.0 vdc at the player. I did not get this same signal at the LDD-1. So seems like i have the signal going in but not out; right?
