I know that there has been a lot of talk about the fan noise on the TM700, so I though I would throw in my 2 cents about the noise, as an owner of the camcorder myself. Instead of cutting mike gain or covering the fan opening, I found that a simple filter in post could remove much of the unwanted fan noise.
Frequencies of the fan:
458 Hz (Lower end hum)
916 Hz (High pitched hum) (Much more dominant)
I found that removing the upper pitched hum made most of the fan noise go away without changing the rest of the audio very much.
Just throw in a narrow filter at 916 Hz and you're good to go.
