AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Need help on choosing a great gaming tv
post #1 of 6
So I'm in need of some help from this great community on choosing a great TV for Gaming, so here's the rundown;
~Budget: 2,000$
~Viewing Distance: acceptable for 40"
~TV size/placement limitations: Again acceptable for 40"
~Uses: Mostly Gaming (FPS, Fighter games, 60 fps games in general) and watching some Blu-ray movies.
~Sources: Xbox 360, PS3 and Wii
So yeah i need some help on this, obviously motion blur is bad for gaming, so a tv having 120Hz should help, though i read somewhere that it produces more input lag, is that true?
Preferably an LCD or LED-LCD, plasmas are to big to fit sadly.
Also a friend of mine recommended the Samsung UN40B7000 that TV any good for gaming?
Thanks in advance guys.
post #2 of 6
Check out the master "help me choose and LCD" thread.
http://www.avsforum.com/avs-vb/showt...ighlight=b7000
post #3 of 6
If you can fit a 50 inch, please, by all means go for the Samsung 8000 series plasma.
post #4 of 6
~Budget: 2,000$
You are in the US? With a $2000 budget, why not go cream of the crop in black levels? Pickup the 55LX9500. Great gaming response time.
post #5 of 6
Yeah plasma was my first choice but the space i'm working with only allows me for a 40" and since i have yet to find a 40" plasma, unfortunately i don't they make 40" plasmas.
What about the Samsung UN40B7000 a friend told me it is great for gaming, not sure what you guys think about this one.
post #6 of 6
Samsung for gaming? er... please consider Sony KDL-40EX700 and Sharp LC-40LE810UN instead, http://tv-compare.blogspot.com/2010/...40le810un.html
