So I am using my laptop, equipped with a Mobility HD 5730 ATI card, as my Blu-ray player for my home theatre and am running Arcsoft Total Media Theatre 5. I run HDMI out from my laptop to my AVR and then hdmi to my LG PK550. I decode the audio on my PC and send a 7.1 LPCM signal to the AVR. Everything works great at 60FPS but as soon as I enable 24FPS in ATI control panel I get a stutter quite frequently on the video. I realize this is because the ATI card is actually outputting 24 frames and not 23.97 which is what is should be. I can select 23FPS in control panel but as soon as I save the changes it defaults back to 24.
I have looked into the Reclock software but that doesn't even work. I installed it and launched the config utility but there is no icon in the tray so I cant access the control panel or get it to do anything. I did set it up with Total Media Theatre as one of the associated programs, but when I launch that Reclock still doesn't show up.
Any solutions? It's ridiculous for people to spend thousands on home theatre PC's and multimedia notebooks and have to have so much trouble settings things up. I had a desktop HTPC before this and nothing ever worked properly without extensive research and trail/error. The PS3 seems to be the much better option at this point.
