Originally Posted by
Wolfpacker96
Maybe I didn't state it clearly, but I have an older receiver that can't decode the newer "HD Audio" codecs. The receiver does handle HDMI, so audio from blurays is output as multichannel PCM (and that what it states on my receiver). The audio from Vudu is showing up on my receiver as Dolby Pro Logic, which means I'm actually only getting 2 channel sound, not 5.1 discrete channels. Can the bluray player even decode DD+? None of the literature I can find states anything about DD+, only Dolby TrueHD. Does anyone know about that?
OK, I see. Then you are probably out of luck, just like I am - I have even older receiver (Denon 3803) that doesn't even have HDMI and does not support DD+. So I have to use coax output out of BDP-S480. I have the same results - Hulk plays as DD and anything encoded as DD+ plays as stereo. It looks like DD+ cannot be down-converted to DD by BDP-S480 or our receivers.
That being said there are 2 settings on BDP-S480 that you can try to tinker with (in Setup/Audio Settings):
a) "BD Audio MIX Setting" (I think by default it is ON but I am not sure)
On my setup if it is ON Dolby TrueHD from BD is played as Stereo. If it is OFF Dolby TrueHD from BD is played as DD 5.1
b) "Dolby Digital". This apparently affects signal outut via Digital OUT, so if you use HDMI it may not affect anything but it is worth tot try to flip between the settings. Or you can try using COAX instead in of HDMI. I have it set to "Dolby Digital".
Wolfpacker96
As far as testing, I opened the first 2 minutes of The Hulk, and I am getting DD. I went back to the 10 minute preview of Contagion, and no surround, though the info states I'm getting DD+. Thought I'd try a different movie and opened the 10 minute preview of Shark Night, and the receiver switched to PCM and I got surround and the info stated DD+. So I guess that one movie I tested was the problem, not my equipment. And I answered my other question about the Sony 480 decoding DD+.
So your receiver does support DD+. It just seems that some movies don't mark the stream correctly for your receiver to recognize it. Then you probably should not even try to mess with settings as I suggested above.
Wolfpacker96
While on the subject of streaming, should I be getting surround on any Netflix streams? I thought I heard a while back that Netflix was adding surround, but I still seem to be getting 2 channel on that as well.
No, you shouldn't be getting surround on Netflix. For this your device should support 1080P streaming from Netflix. Only devices that support this that I know of are PS3 and Roku 2 - XD and XS.
But you should be able to get surround from Amazon streaming - most recent movies in HD use DD. However, Amazon HD is only 720P.
