Hello!
Right now I am considering going with either Danley's SH-50 or SH-60 as FCR for a pretty high end home theater setup.
My upcoming dedicated room will be about 22'x19'x12'. I have been using 5x Genelec 1037Cs for the past couple of years. Before that I made my experiences with horn speakers: Klipschhorn, THX ULTRA 2, JBLs and even Avantgarde Acoustics at some point. I generally like the sound signature of horn speakers.
Lately I bought a Seaton Catalyst 12C to benchmark it against the Genelecs - you can read about it over here: http://www.seaton-sound-forum.com/post?id=4897368
In short: I am not quite satisfied with the relative performance of the Catalyst versus the Genelecs - despite its much greater dynamic headroom.
So I am thinking about going back to my first love - horn speakers. And that's were Danley enters the picture...
I would appreciate it to get some advice on the following points:
- I am considering the SH-50 or the SH-60. Both will work in my setup and the ~12 feet listening distance. I noticed that the driver/component configuration is different (6x4" versus 4x5"). I take it the SH-60 is the more recent design. What are the differences between those two regarding "sound quality" (other than the different dispersion)?
- Both speaker come in a passive and active version. The active uses IcePower moduls with DSP crossovers just like the Seaton Catalyst does (they use the same OEM for the amps). My question is: Would the version with passive crossovers together with a decent external amp (I am thinking about the MC2 MC 1250) give me "better sound quality" compared to the powered version? I guess the tri-amplified Class D amp with digital crossovers has its advantages but I don't like the concept of going through additional A/D-D/A steps.
I take it Tom Danley himself uses the passive version together with external amps. Is SQ the reason for that? (Note: I don't have any amps right now that I could simply use - so the question is whether to buy the "turn key active version" or the passive one with appropriate amps).
- Are there any European Danley dealers listening?
I am looking forward to any advice! Thanks.
- Walter
- Walter
