Originally Posted by forin
Semi bump, 6th page is to far back for this thread
Ivan, Ive been playing with crossover settings between the dts-10 and sm60f, I used to have everything @ 80hz. Now I have the sh-100 at 70 micros at 80hz and am torn between 50hz and 60hz for the sm-60s. Do you think 50hz hp is to low for the sm-60s? Its been hard isolating content that is 70-40 hz in movies.
Forin
Forin
You would be fine. In fact if you are not pushing them to the limit (most people would be nowhere near this in a home situation), you can actually apply a little boost down around 50-60Hz to "fill them out" a little bit.
Do you have a choice of HP filter types and slopes? If so, then use a 24dB Butterworth to get the most extension and flattest response down to the crossover.
