Yes I did. However, after setting up my front stage with 3 SH50s I decided to proceed with other things first and then with the purchase of the surrounds. I tuned the JBLs for the moment. I want to build custom telescopic stands for the SH50s since after playing around with them I decided that placement and height as well as the angle of them have great effect on their sound. So I will soon order them to a machine shop since I want them to fit perfectly with the SH50s. Yet, I will ask for a tilting option for them. They will be cut to the same shape as the SH50s, will be telescopic for perfect height adjustment and on hidden steel balls for the proper angle. After that I will go ahead with room treatments and then I will start on the surrounds that will probably be the SM96s for increased mid bass. Another option would be the SM100Bs. I have not concluded on the surrounds yet and since those I am thinking of are quite expensive I will take my time. I will post pictures when I start (quite busy with work lately) with the Room and the custom bases.
post #661 of 684
1/11/13 at 3:28pm
