Originally Posted by groupah
new set x 1 week. I've noticed that there is a lip sync delay on non HD channels where the picture is bracketed by side-bars. All the full picture channels and movies are fine.
Also, the picture and audio adjustment menu can only be accessed through the TV input when there is no picture or audio in the backround. Is this possible, or am I simply missing the obvious?
Any help would be appreciated.
There are quite a few scenarios when the access to the menu and other functions is limited to certain inputs but still accessible from the VIA apps. I run into this quite often using a Denon AVR 891 with HDMI pass-thru and it can change based on setup. I contacted Vizio and they acknowledge this to be true but have no remedy. In these cases I either get to the menu via the VIA ribbon OR change inputs, go to the menu, and then on the menu change back to the input I was on to do the adjustments.
