AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Finally ready to replace my VW100(Ruby) - which forum should I be in? :)
post #1 of 5
My second bulb has taken on the ever-annoying flicker that plagued the first.. and I don't feel like coughing up 700+ for a third. My main goal is not to lose anything vs the VW100. Regarding content, I do about 50/50% gaming/movies (no TV, sports, etc). I always felt that the Ruby did a great job at both, so I want to be certain I dont go too cheap and take any steps back.
Vs the VW100, the new projector should have:
- as good or better black level
- same or faster response time (gaming - Ruby was awesome here)
- comparable color accuracy and intra-scene contrast (hopefully better w/ Reds in dark scenes - ruby had a goofy gamma curve w/ red)
- cheaper bulbs
- as sharp or (preferably) sharper
So - any ideas what the cheapest thing is out there that will do all of those things as good as or better than the ol' VW100? Can something found in the <3000 forums match or best the Ruby on all fronts, or am I still stuck in here with you big spenders?
post #2 of 5
For a cheaper Ruby bulb (<$400), make a search on eBay for "Replacement Lamp LMP-H400 for Sony modules".
If your present flickering lamp is younger than 2500h, and your VW100 S/N is below or equal to 2003986, installing the Sony Hard Start Mod Kit [A1206459A] will likely resurrect your lamp; if your S/N is between 2003987 - 2005136, you will need instead Sony Igniter Assy [A1206462A].
I have a 5 years old Ruby, but every time I check a possible replacement (VW90 included), I miss the great colors of the Xenon lamp. Let us know if you find a successor you like.
--edited the S/N range (inverted, sorry)--
post #3 of 5
If your present flickering lamp is younger than 2500h, and your VW100 S/N is below or equal to 2003986, replacing the Sony Igniter Assy [A1206462A] will likely resurrect your lamp; if your S/N is between 2003987 - 2005136, you will need instead Sony Hard Start Mod Kit [A1206459A].
Wow, thanks! That was a tremendously helpful reply. The lamp started flickering at around the 500h mark and has gotten progressively worse - I'd always though it was something in the projector but having sent the projector in twice under warranty and had it come back no better than when I sent it off, I'd given up on that front.
How difficult are those parts to install, and will I be able to track down instructions? I've repaired a couple LCD monitors and more than a few pinball PCB's, so I'd probably be ok doing the install if it's just a few solder points, but beyond that I suppose I'd be tracking down a service center.
I bought my Ruby shortly after they launched, so I suspect it must be the igniter assy.
post #4 of 5
Normally, Sony Prime Support was supposed to install the Hard Start Mod Kit for free under warranty when the projector was serviced. Except that they did not always do it : in my case for instance, when the lamp began to have start problems (click-click-click...) then finally failed to start at all, they told me the only solution was to replace it, although I had still 2 months of Prime Support to go. Had to pay myself for the parts when I discovered the true origin of the problem AFTER I had exhausted Prime Support...
If you kept your receipts for the 2 times you sent it, check anyway the replacement for "HARD START MOD KIT" or "IGNITER ASSY" was never performed.
PM me with your email address, I will send you the installation instructions pdf so you can check for yourself.
Only way to be sure is to check the S/N and to verify Sony did not replace it under warranty when you sent it.
Worst case cost [A1206459A, for S/N<=2003986] is $700, best case [A1206462A, for S/N between 2003987-2005136] is $200.
Sorry, my initial post inverted the S/N ranges - edited since.
But if it works (don't sue me if it does not, no warranty there ;-), you will recover the cost of the lamp which is not working, extending its life to its normal end (2000-2500h).
post #5 of 5
I think the JVC projectors would be a good replacement for the Sony. You can go cheaper but you they wont be comparable to what you got. Bulbs should be cheaper than the Sony. I would stay with the 3000 and over projector section
