How does it sound?
I've had a bit of an awakening on the DAC quality issue. A while back I did some serious testing of my old 83SE on analog 2 channel SACDs versus the same song on regular CD. There was a noticeable difference for the better on the Oppo, as expected.
I've swapped out a fair number of pieces since then. I went to the 95 for one. Now I'm running the new Emotive UMC-200. I tried a Rotel a few years back, but there were too many pops and non-lock issues for me. The UMC-200 was intended to mainly provide a clean path fro the Oppo.
The UMC-200 uses a version of a Cirrus chip - I think. I also have an external DAC I bought for my housewide system. That one is not that expensive ($300 range), but also runs a Cirrus, and has a tube stage. The idea of the tube DAC was to warm up the sound from my old Escient Fireball music server, which is seems to do.
I have a couple nice 2-channel SACDs I like - Jeff Beck - Blow by Blow and Peter Gabriel - So. The mellow tunes show off my system.
Its hard to believe, but the SACD from the Oppo, going on a direct analog path sounds pretty much the same as the tube DAC converting a bitstream from the Fireball read from a FLAQ ripped from a CD. Hmmm. Then the UMC-200 decoding the same bitstream, with room correction running on the DSP, probably sounds a bit better to me. hmmm. I brought my wife an daughter down to each listen. My daughter said the tube DAC made the vocals on So sound a bit more raspy, which she though would have been Peter's intention. Now there is an audiophile in the making. My wife liked the tube DAC too, saying the SACD sounded too perfect. I thought they all sounded so close, its hard to tell.
So I'm guessing the decent DACs are a lot closer to the high end DACs than a few years back. The only other variable is that I went to a bi-amp setup on my main speakers, using a tube to drive the horns. Maybe that is warming everything up to make the differences super subtle? I think I really underestimated the value of room EQ too. Its only tweaks here and there, but overall its better.
Originally Posted by
VicTorious1
The speakers I have hooked up to the Marantz SR6007 are Gallo CL-3s (I'm also in home auditioning B&W 683s and PSB T6s, so far the Gallo sound the best followed by the T6s). I do not hear any buzz from any of the speakers I'm currently auditioning. I've also tested the noise floor of the CL-3s with the WOW calibration DVD.
