WOW...7 pages...and still no pictures! C'mon....fellas.......post some excellent photos of the unit...front, back, innards................
post #181 of 10457
2/3/11 at 6:55am
), please keep the reviews coming !
Only true if you wanted to use FAT. Not true for anyone who is seriously using external HDD backups, as they will be using NTFS (universally supported by all major operating systems. For Mac use Paragon's NTFS for Mac or NTFS-3G).
No need for the colors, the bold, or the font size. We are capable of reading an entire post without guideposts/markers. Is this from your FLAC media or another format? Do you have a file that we can download to replicate your errors? If you use a different interface, such as digital coaxial/optical or HDMI, do you hear the same noises? |
Are you talking about the relay clicks in the 95? That's the audio muting and unmuting. It will happen if you do a manual mute. It will also happen when the audio is automatically muted during HDMI handshakes -- as for example when the resolution changes.
The relays are used instead of transistors for improved analog audio output quality. --Bob |
Coax digital out from the BDP-95 into DAC1 HDR, then DAC1 HDR XLR outs to Jeff Rowland Concerto integrated amp, then Dali Helicon 400mk2 floor-stand speakers. This sounds better than going BDP-95 XLR outs to the Jeff Rowland. I tried it with a number of reference CDs as well as Dolby Digital material (converted to two-channels).
By the way, the difference in sound quality between the DAC1 HDR and the BDP-95 is more significant than the difference between the SA-7S1 and the DAC1 HDR. I have to listen to some fairly minute difference to distinguish between the Marantz and the Benchmark, but the difference between the Benchmark and the Oppo is not minute. Still, The Oppo has a very good and enjoyable sound.
It could be break-in. Will know more in a week or so. Its possible.
Again, just to not be misinterpreted, the Blu-ray VIDEOS audio sounds fine. DVD-A is great. SACD very good. CD, not so much, but it is also going through a redigitizing stage on my proc. Blu-ray AUDIO only discs also are not what I had hoped, but it could be the discs since these are brand new and I have no frame of reference. Will definitely be doing more tests, but for now concentrating on getting the wireless networking to work - which has me baffled. ~Bob |
Originally Posted by rebop
It could be break-in. Will know more in a week or so. Its possible. Again, just to not be misinterpreted, the Blu-ray VIDEOS audio sounds fine. DVD-A is great. SACD very good. CD, not so much, but it is also going through a redigitizing stage on my proc. Blu-ray AUDIO only discs also are not what I had hoped, but it could be the discs since these are brand new and I have no frame of reference. Will definitely be doing more tests, but for now concentrating on getting the wireless networking to work - which has me baffled. ~Bob |
"The relays are used instead of transistors for improved analog audio output quality." What does that mean? I am not a tech guy just loves music
Yes HDMi handshakes! why does it mute the audio? |
I'll be interested in your opinion of the redbook performance after you've given the 95 some more time to burn. I've been using a Denon 3930CI for quite awhile. I bought an 83SE last year but returned it since, to my ears, the Denon was the better CDP. The Denon was more involving, refined and musical. The Oppo was more analytical and did "not draw me in" as they say. One obvious and repeatable clue was the decay. Denon was definitely smoother, more extended and natural. The Oppo did get better after a week or so but never got me to "Ah". I have the itch for a 95 but only if its 2 channel audio bests the Denon
