Originally Posted by Esteban Medaglia
Bob, I just wanted to extend my thanks once again. You offer priceless, step-by-step advice and no-nonsense, thorough information here. I am learning a lot. After following your recommendations and finally understanding why things were happening the way they were, and having experimented with the different set-ups, I decided to keep the SACD output as PCM which, like you said, makes life a lot easier and still delivers terrific quality!
As far as the 24/192 files, does the Oppo accept those natively, or does it "down-convert" those types of files to 24/96 or any other format?
The DACs handle 192/24 natively for analog output. The HDMI is able to output up to 7.1 channels of 192/24, *IF* the thing at the other end of the cable will accept that. That gets negotiated during the HDMI handshake.
There is one potential Gotcha in this for the specific format 5.1 DTS-HD MA 192KHz: If using LPCM or analog output, the Oppo will decode that as 96KHz. This is a processor limitation so it won't change in firmware. However if you output that track as HDMI Bitstream, the full 192KHz gets sent to your AVR for decoding in the AVR (presuming your AVR allows that -- note that many AVRs will ALSO decode that as only 96KHz).
Note that this is JUST for this one specific format. As it turns out, the Blu-ray spec does not even allow support of DTS-HD MA at 7.1 192KHz, so the format limit for DTS 7.1 is already just 96KHz. And 2.0 DTS-HD MA 192KHz gets decoded at 192KHz without problem.
Furthermore, the player has no problem decoding (or outputting Bitstream) for either 5.1 or 7.1 Dolby TrueHD 192KHz at the full 192KHz -- both of which are supported in the Blu-ray format spec.
Another possible Gotcha arises for folks trying to use high bit rate tracks from DLNA servers. There have been mixed results with DTS-HD MA tracks in ripped video files for some file formats. At the moment, it looks like that may be due to server limitations but that's still up in the air. In any event, the player is not recovering cleanly when those problems happen. There's been more discussion of this in the 93 thread.
--Bob
